<?xml version="1.0" encoding="UTF-8"?><process version="9.7.000"><br> <context><br> <input/><br> <output/><br> <macros/><br> </context><br> <operator activated="true" class="process" compatibility="9.7.000" expanded="true" name="Process"><br> <parameter key="logverbosity" value="init"/><br> <parameter key="random_seed" value="2001"/><br> <parameter key="send_mail" value="never"/><br> <parameter key="notification_email" value=""/><br> <parameter key="process_duration_for_mail" value="30"/><br> <parameter key="encoding" value="SYSTEM"/><br> <process expanded="true"><br> <operator activated="true" class="utility:create_exampleset" compatibility="9.7.000" expanded="true" height="68" name="Create ExampleSet" width="90" x="45" y="85"><br> <parameter key="generator_type" value="attribute functions"/><br> <parameter key="number_of_examples" value="100"/><br> <parameter key="use_stepsize" value="false"/><br> <list key="function_descriptions"><br> <parameter key="date" value="date_add(date_now(),round(rand())*50,DATE_UNIT_DAY)"/><br> <parameter key="Generated ID" value="id%10"/><br> <parameter key="random" value="rand()"/><br> </list><br> <parameter key="add_id_attribute" value="true"/><br> <list key="numeric_series_configuration"/><br> <list key="date_series_configuration"/><br> <list key="date_series_configuration (interval)"/><br> <parameter key="date_format" value="yyyy-MM-dd HH:mm:ss"/><br> <parameter key="time_zone" value="SYSTEM"/><br> <parameter key="column_separator" value=","/><br> <parameter key="parse_all_as_nominal" value="false"/><br> <parameter key="decimal_point_character" value="."/><br> <parameter key="trim_attribute_names" value="true"/><br> </operator><br> <operator activated="true" class="remove_duplicates" compatibility="9.7.000" expanded="true" height="103" name="Remove Duplicates" width="90" x="179" y="85"><br> <parameter key="attribute_filter_type" value="subset"/><br> <parameter key="attribute" value=""/><br> <parameter key="attributes" value="Generated ID|date"/><br> <parameter key="use_except_expression" value="false"/><br> <parameter key="value_type" value="attribute_value"/><br> <parameter key="use_value_type_exception" value="false"/><br> <parameter key="except_value_type" value="time"/><br> <parameter key="block_type" value="attribute_block"/><br> <parameter key="use_block_type_exception" value="false"/><br> <parameter key="except_block_type" value="value_matrix_row_start"/><br> <parameter key="invert_selection" value="false"/><br> <parameter key="include_special_attributes" value="false"/><br> <parameter key="treat_missing_values_as_duplicates" value="false"/><br> </operator><br> <operator activated="true" class="concurrency:join" compatibility="9.7.000" expanded="true" height="82" name="Join" width="90" x="380" y="85"><br> <parameter key="remove_double_attributes" value="true"/><br> <parameter key="join_type" value="inner"/><br> <parameter key="use_id_attribute_as_key" value="false"/><br> <list key="key_attributes"><br> <parameter key="Generated ID" value="Generated ID"/><br> <parameter key="date" value="date"/><br> </list><br> <parameter key="keep_both_join_attributes" value="false"/><br> </operator><br> <operator activated="true" class="sort" compatibility="9.7.000" expanded="true" height="82" name="Sort" width="90" x="514" y="85"><br> <parameter key="attribute_name" value="random"/><br> <parameter key="sorting_direction" value="decreasing"/><br> </operator><br> <connect from_op="Create ExampleSet" from_port="output" to_op="Remove Duplicates" to_port="example set input"/><br> <connect from_op="Remove Duplicates" from_port="example set output" to_op="Join" to_port="left"/><br> <connect from_op="Remove Duplicates" from_port="duplicates" to_op="Join" to_port="right"/><br> <connect from_op="Join" from_port="join" to_op="Sort" to_port="example set input"/><br> <connect from_op="Sort" from_port="example set output" to_port="result 1"/><br> <portSpacing port="source_input 1" spacing="0"/><br> <portSpacing port="sink_result 1" spacing="0"/><br> <portSpacing port="sink_result 2" spacing="0"/><br> </process><br> </operator><br></process><br><br>
