Trying to call an Oracle stored procedure using the Execute SQL operator and getting
Database error occurred: ORA-00900: invalid SQL statement.
The SP I'm trying to call is located within the schema that I've configured the connection for.
I can execute the SP successfully while connected via SQL Developer.
I've tried:
EXECUTE <SP_NAME>
EXECUTE <SCHEMA>.<SP_NAME>
EXEC <SP_NAME>
EXEC <SCHEMA>.<SP_NAME>
I was able to successfully run SELECT SYSDATE FROM DUAL using Execute SQL operator.
Thanks in advance.
