Delete columns
sara20
Hello
When I want to import my data to RM at first I see RM understand
duplicate columns so I can not import it to RM. It would be nice if I can import it to the RM then can delete duplicate columns. Also it would be nice if we could do association mining rule with Auto model.
regards
sara
David_A
Hi
@sara20
to handle duplicate column names during import you can do the following:
Don't define a header column (depending on the actual method, there is a checkbox for that in the wizard)
Then delete the duplicate column (for example with Select Attributes operator)
Use the
Rename by Example Values
operator to select the first row (which contains the original header names) to get back the original names
Afterwards you probably need to use
Parse Numbers
and
Nominal to Date
to get the correct value types for all attributes
Best,
David
Edit:
Even simpler is the option to rename the duplicate columns by hand while importing, but that's only feasible with a few duplicate names.
sara20
@David_A
Thank you very much
This is big data and it is not possible to do any changes with hand. But other points are very useful
Regards
sara
