<?xml version="1.0" encoding="UTF-8"?><process version="9.6.000"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="9.6.000" expanded="true" name="Process"> <parameter key="logverbosity" value="init"/> <parameter key="random_seed" value="2001"/> <parameter key="send_mail" value="never"/> <parameter key="notification_email" value=""/> <parameter key="process_duration_for_mail" value="30"/> <parameter key="encoding" value="SYSTEM"/> <process expanded="true"> <operator activated="true" class="utility:create_exampleset" compatibility="9.6.000" expanded="true" height="68" name="Dummy data" width="90" x="179" y="187"> <parameter key="generator_type" value="numeric series"/> <parameter key="number_of_examples" value="100"/> <parameter key="use_stepsize" value="false"/> <list key="function_descriptions"/> <parameter key="add_id_attribute" value="false"/> <list key="numeric_series_configuration"> <parameter key="a" value="linear.0\.0.1\.0"/> <parameter key="b" value="quadratic.0\.0.1\.0"/> <parameter key="c" value="square root.0\.0.1\.0"/> </list> <list key="date_series_configuration"/> <list key="date_series_configuration (interval)"/> <parameter key="date_format" value="yyyy-MM-dd HH:mm:ss"/> <parameter key="time_zone" value="SYSTEM"/> <parameter key="column_separator" value=","/> <parameter key="parse_all_as_nominal" value="false"/> <parameter key="decimal_point_character" value="."/> <parameter key="trim_attribute_names" value="true"/> </operator> <operator activated="true" class="utility:create_exampleset" compatibility="9.6.000" expanded="true" height="68" name="Rename row" width="90" x="179" y="34"> <parameter key="generator_type" value="comma separated text"/> <parameter key="number_of_examples" value="100"/> <parameter key="use_stepsize" value="false"/> <list key="function_descriptions"/> <parameter key="add_id_attribute" value="false"/> <list key="numeric_series_configuration"/> <list key="date_series_configuration"/> <list key="date_series_configuration (interval)"/> <parameter key="date_format" value="yyyy-MM-dd HH:mm:ss"/> <parameter key="time_zone" value="SYSTEM"/> <parameter key="input_csv_text" value="a, b, c apple, ball, cat"/> <parameter key="column_separator" value=","/> <parameter key="parse_all_as_nominal" value="false"/> <parameter key="decimal_point_character" value="."/> <parameter key="trim_attribute_names" value="true"/> </operator> <operator activated="true" class="operator_toolbox:advanced_append" compatibility="2.3.000" expanded="true" height="103" name="Append (Superset)" width="90" x="380" y="34"/> <operator activated="true" class="rename_by_example_values" compatibility="9.6.000" expanded="true" height="82" name="Rename by Example Values" width="90" x="581" y="34"> <parameter key="row_number" value="1"/> </operator> <operator activated="true" class="guess_types" compatibility="9.6.000" expanded="true" height="82" name="Guess Types" width="90" x="715" y="34"> <parameter key="attribute_filter_type" value="all"/> <parameter key="attribute" value=""/> <parameter key="attributes" value=""/> <parameter key="use_except_expression" value="false"/> <parameter key="value_type" value="attribute_value"/> <parameter key="use_value_type_exception" value="false"/> <parameter key="except_value_type" value="time"/> <parameter key="block_type" value="attribute_block"/> <parameter key="use_block_type_exception" value="false"/> <parameter key="except_block_type" value="value_matrix_row_start"/> <parameter key="invert_selection" value="false"/> <parameter key="include_special_attributes" value="false"/> <parameter key="decimal_point_character" value="."/> </operator> <connect from_op="Dummy data" from_port="output" to_op="Append (Superset)" to_port="example set 2"/> <connect from_op="Rename row" from_port="output" to_op="Append (Superset)" to_port="example set 1"/> <connect from_op="Append (Superset)" from_port="merged set" to_op="Rename by Example Values" to_port="example set input"/> <connect from_op="Rename by Example Values" from_port="example set output" to_op="Guess Types" to_port="example set input"/> <connect from_op="Guess Types" from_port="example set output" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator> </process>
<?xml version="1.0" encoding="UTF-8"?><process version="9.6.000"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="9.6.000" expanded="true" name="Process"> <parameter key="logverbosity" value="init"/> <parameter key="random_seed" value="2001"/> <parameter key="send_mail" value="never"/> <parameter key="notification_email" value=""/> <parameter key="process_duration_for_mail" value="30"/> <parameter key="encoding" value="SYSTEM"/> <process expanded="true"> <operator activated="true" class="read_excel" compatibility="9.6.000" expanded="true" height="68" name="Your default file" width="90" x="112" y="85"> <parameter key="excel_file" value="C:\Users\harsh\Downloads\old_columns.xlsx"/> <parameter key="sheet_selection" value="sheet number"/> <parameter key="sheet_number" value="1"/> <parameter key="imported_cell_range" value="A1"/> <parameter key="encoding" value="SYSTEM"/> <parameter key="first_row_as_names" value="true"/> <list key="annotations"/> <parameter key="date_format" value=""/> <parameter key="time_zone" value="SYSTEM"/> <parameter key="locale" value="English (United States)"/> <parameter key="read_all_values_as_polynominal" value="false"/> <list key="data_set_meta_data_information"> <parameter key="0" value="PARAMETER_VALUE_1.true.polynominal.attribute"/> <parameter key="1" value="PARAMETER_VALUE_2.true.integer.attribute"/> <parameter key="2" value="PARAMETER_VALUE_3.true.polynominal.attribute"/> <parameter key="3" value="PARAMETER_VALUE_4.true.polynominal.attribute"/> <parameter key="4" value="PARAMETER_VALUE_5.true.polynominal.attribute"/> </list> <parameter key="read_not_matching_values_as_missings" value="false"/> <parameter key="datamanagement" value="double_array"/> <parameter key="data_management" value="auto"/> </operator> <operator activated="true" class="utility:create_exampleset" compatibility="9.6.000" expanded="true" height="68" name="Create ExampleSet" width="90" x="246" y="289"> <parameter key="generator_type" value="comma separated text"/> <parameter key="number_of_examples" value="100"/> <parameter key="use_stepsize" value="false"/> <list key="function_descriptions"/> <parameter key="add_id_attribute" value="false"/> <list key="numeric_series_configuration"/> <list key="date_series_configuration"/> <list key="date_series_configuration (interval)"/> <parameter key="date_format" value="yyyy-MM-dd HH:mm:ss"/> <parameter key="time_zone" value="SYSTEM"/> <parameter key="input_csv_text" value="PARAMETER_VALUE_1,PARAMETER_VALUE_2,PARAMETER_VALUE_3,PARAMETER_VALUE_4,PARAMETER_VALUE_5 att1	,att2,att3,att4,att5 "/> <parameter key="column_separator" value=","/> <parameter key="parse_all_as_nominal" value="false"/> <parameter key="decimal_point_character" value="."/> <parameter key="trim_attribute_names" value="true"/> </operator> <operator activated="true" class="operator_toolbox:advanced_append" compatibility="2.3.000" expanded="true" height="103" name="Append (Superset)" width="90" x="447" y="85"/> <operator activated="true" class="rename_by_example_values" compatibility="9.6.000" expanded="true" height="82" name="Rename by Example Values" width="90" x="648" y="187"> <parameter key="row_number" value="1"/> </operator> <operator activated="true" class="guess_types" compatibility="9.6.000" expanded="true" height="82" name="Guess Types" width="90" x="782" y="187"> <parameter key="attribute_filter_type" value="all"/> <parameter key="attribute" value=""/> <parameter key="attributes" value=""/> <parameter key="use_except_expression" value="false"/> <parameter key="value_type" value="attribute_value"/> <parameter key="use_value_type_exception" value="false"/> <parameter key="except_value_type" value="time"/> <parameter key="block_type" value="attribute_block"/> <parameter key="use_block_type_exception" value="false"/> <parameter key="except_block_type" value="value_matrix_row_start"/> <parameter key="invert_selection" value="false"/> <parameter key="include_special_attributes" value="false"/> <parameter key="decimal_point_character" value="."/> </operator> <connect from_op="Your default file" from_port="output" to_op="Append (Superset)" to_port="example set 2"/> <connect from_op="Create ExampleSet" from_port="output" to_op="Append (Superset)" to_port="example set 1"/> <connect from_op="Append (Superset)" from_port="merged set" to_op="Rename by Example Values" to_port="example set input"/> <connect from_op="Rename by Example Values" from_port="example set output" to_op="Guess Types" to_port="example set input"/> <connect from_op="Guess Types" from_port="example set output" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator> </process> <b></b>
