Motion View USRMES:USER [316001] WARNING: could not set time
draucis
draucis Altair Community Member
edited January 2023 in Community Q&A
I have set my two-wheeler model with the help of the assembly wizard. The analysis I am using runs fine as long as I don't close the file but once it is opened again from the saved document this error is there and I have to kill the solver as it keeps on running with this error.
Regards
Draucis
Best Answer
  • Praful
    Praful
    edited January 2023 Answer ✓
    Hi Draucis - Could you please share  if possible the model and associated files if any?
    regards
    Praful
    Never mind.
    There is likely a bug in the FMU entity of the powertrain.
    If you see the "Static Hold" as Off after you load the model, turn it on and save the model. Then onwards, it should work fine.
    You should only need this to do once.
    Try it and please comment how it goes.
    Regards
    Praful
  • Praful
    Praful
    edited January 2023
    regards
    Praful
  • Praful
    Praful
    regards
    Praful
    Never mind.
    Regards
    Praful
  • draucis
    edited January 2023
    Hi Praful,
    Thank you so much for your help. Yes, your diagnosis was correct after turning on the static hold the 'cannot set time' error has solved.
    Regards
    Draucis
