How can I apply SMOTE for multi-class Classification of NSL-KDD data set in RapidMiner?
YeshSWJTU
I am working on feature selection in Network Intrusion Detection System (NIDS) using NSL-KDD
data set.
In NSL-KDD data set, there are five classes Normal, DoS, Probe, U2R and R2L. But the classes are extremely imbalanced specially U2R and R2L. I am trying to balance this data set using SMOTE and to dynamically balance the data set. But i am getting problem to solve using rapid miner. I can apply SMOTE using WEKA but, i need to balance
dynamically using RapidMiner. I need your help Thank you
Classification
SMOTE
Telcontar120
There is a SMOTE Upsampling operator for RapidMiner in the Operator Toolbox, which you will need to install from the extension marketplace (it is free). You might also consider using weighting instead of upsampling depending on the ML algorithm you intend to use. There are several suitable weighting operators available in the base Studio installation.
YeshSWJTU
Telcontar120
Thank you for your response. I tried SMOTE Upsampling but it is not supporting to balance multiple minority classes. It works for binary classification. I will check the weighting operators if it works. thank you
MartinLiebig
Hi
@YeshSWJTU
did you try to set the minority class manually in SMOTE?
Best,
Martin
YeshSWJTU
mschmitz
I tried to set manually but neither it detect the minority class automatically nor it works manually (for binary classification). There is no option for multiple minority classes. Thank you!
