you can define it by setting the preferences under 'Hardware settings'.
If the efficient core's are "visible" to SimSolid, it can use them.
you can define it by setting the preferences under 'Hardware settings'. If the efficient core's are "visible" to SimSolid, it can use them.
Adriano,
Thanks.
Hardware settings does not distinguish between Performance and Efficient cores.
So if I set the number of cores to use at less than the number of logical cores available which cores are not being used?
Ross
