Can not to start the RapidMiner Server
Yi_Yao
Dear,
I installed the RM Server, but I could not start it. I tried the three ways provided in the document but all failed. The error informations are shown below.
Server
aschaferdiek
Hi. Could you please try to start RapidMiner Server by double-clicking on the standalone.bat file within the installation directory bin/ folder?
Yi_Yao
Hi, I double-clicked the standalone.bat file within the installation directory bin/ folder. The result is shown below as the second picture in the question.
aschaferdiek
Thanks for the screenshot. Are we sure that your machine meets the minimum requirements? How much memory does it have?
Yi_Yao
The memory in my laptop is 16G. It is a new machine and I think it definitely meets the minimum requirements.
aschaferdiek
That should be enough, indeed. Is there any log written to the rapidminer-server-home/log folder which you could share?
Yi_Yao
A log text file is attached. It shows that "JAVA_HOME is not set". While I had already added the variable into the environment.
standalone.log
aschaferdiek
I read that this might pop up when your system is 64bit but your installed version of JRE is 32bit. Could you verify that you're using the correct JRE distribution?
Yi_Yao
It was resolved. I add an environment variable "JAVA_HOME" to the System Variable and it works. At the beginning, I add the JAVA_HOME variables to the User Variable. Thanks a lot for your help!!!
aschaferdiek
Ok, good to know. Thanks for sharing the solution.
