How to share your auto model results and turbo prep charts with another user
StudentNZ
Hi
I am a student and I have to submit the analysis and charts that I have done in Rapidminer studio with my dataset.
I need to submit this to my professor and he has a rapidminer account.
Could you please advise how to do this.
For example, students who use power BI have given the power BI file to the professor.
Thanks and Regards
Student NZ
Visualization + Dashboards
Auto Model
Turbo Prep
Telcontar120
You have a few options here.
You can directly export the RapidMiner processes associated with your work from either AM or TP.
You could also save the chart exhibits and put them into another document to share directly.
Both are simple to do within RapidMiner, check under the "file" menu.
StudentNZ
Hi Brian, Thank you very much. What is AP or TP ? please clarify. sorry didn't get that as I am new to Rapid Miner. Thanks and Regards
lionelderkrikor
Hi
@StudentNZ
AM = AutoModel
TP = Turbo Prep
If you are using AM (thus Auto-Model), you can save all your results by clicking on the "Save Results" button once the results are displayed (on the final screen of AM - the "results" screen).
More over, as mentioned by Brian, you can export your process by clicking on:
File
Export Process
and then choose a path where your process (.rmp file) will be stored.
Lionel
lionelderkrikor
@StudentNZ
In the TP screen, make your manipulation(s) and then click on
CREATE PROCESS.
Then you can, as I said in my previous post, go to
File -> Export Process.
To share your prepared data you can click on
Export
and then choose the appropriate format to save your prepared data.
then
Lionel
lionelderkrikor
@StudentNZ
I'm sorry, I'm not able to reproduce your error : The manipulation you describe works fine for me.
In order the RM staff can investigate the error you encountered, can you provide :
- Your operating system.
- Your RM version.
- Your RapidMiner log file : This file called "
rapidminer-studio.log"
is stored under
"C:\Users\username\.RapidMiner"
Lionel
lionelderkrikor
Hi
@StudentNZ
Yes, I have imported your folder in RapidMiner repository and all seems to work :
Lionel
Telcontar120
StudentNZ
lionelderkrikor
Hi
@StudentNZ
AM = AutoModel
TP = Turbo Prep
File
Export Process
Lionel
StudentNZ
Dear Lionel
Thank you so much. Could you please also advise how to save TP results and process so that I can choose and run it later on or share the repository with my professor to run to assess my work in his account.
Best Regards
lionelderkrikor
@StudentNZ
CREATE PROCESS.
Export
then
Lionel
StudentNZ
Hi
I am creating pivot and chart in TP and then exporting like you showed above into respository.
When I come back to see the results on another day an click on file in repository to see the visualisation - i am getting following error
I am getting following error when I click on the results saved in the repository an press visualisation for some files.
Please see attached image and below details
Exception: java.nio.file.InvalidPathException
Message: Trailing char < > at index 42: Local Repository//education versus deposit
Stack trace:
sun.nio.fs.WindowsPathParser.normalize(WindowsPathParser.java:191)
sun.nio.fs.WindowsPathParser.parse(WindowsPathParser.java:153)
sun.nio.fs.WindowsPathParser.parse(WindowsPathParser.java:77)
sun.nio.fs.WindowsPath.parse(WindowsPath.java:94)
sun.nio.fs.WindowsFileSystem.getPath(WindowsFileSystem.java:255)
sun.nio.fs.AbstractPath.resolve(AbstractPath.java:53)
com.rapidminer.repository.PersistentContentMapperStore.retrieve(PersistentContentMapperStore.java:280)
com.rapidminer.repository.PersistentContentMapperStore.retrieve(PersistentContentMapperStore.java:234)
com.rapidminer.extension.html5charts.gui.ChartModel.(ChartModel.java:87)
com.rapidminer.extension.html5charts.gui.renderer.AbstractVisualizationRenderer.getVisualizationComponent(AbstractVisualizationRenderer.java:118)
com.rapidminer.gui.processeditor.results.ResultDisplayTools$1.run(ResultDisplayTools.java:171)
com.rapidminer.gui.tools.ProgressThread$3.run(ProgressThread.java:586)
java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149)
java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624)
java.lang.Thread.run(Thread.java:748)
lionelderkrikor
@StudentNZ
- Your RM version.
is stored under
Lionel
StudentNZ
StudentNZ
Hi
I have managed to save all my work and run it as per all the fantastic advice that I have got on this forum.
Can I share the folder attached herewith with someone and if someone here can please run it on their local Rapidminer Studio and see the graphs. Then I can be assured that my professor also will be able to see it and its working well.
Look forward to your help. Would be very grateful for the same.
Best Regards
StudentNZ
lionelderkrikor
Hi
@StudentNZ
Lionel
StudentNZ
Thank you so much Lionel for your help. Much appreciated. Warm Regards
StudentNZ
Hi All
Is there a way to perform sensitivity analysis on the my dataset attached above in rapidminer ?
Best Regards
Shailey
