How can I compare values from two tables?
User: "shörly"
New Altair Community Member
Updated by Jocelyn
Hello together,
i want to compare values from two tables.
I have a table with a number, a date and a weight. In the other table I have the same number, date and level.
I want to compare the weight with the level.
How do I do that?
Can you help me there?
Thank you very much and best regards,
Sharleen
1 - 1 of 11
    User: "David_A"
    this sounds like you want to join both tables by that number. Afterwards you can use TurboPrep or the Generate Attributes operator to create a comparison between the weight and the level.
    Best,
    David
