Same I am trying to achieve using Enrich_data_by_webservice operator but everytime I do I am getting some error with various integration. Can anyone help me out. Below is the process I am using:-<?xml version="1.0" encoding="UTF-8"?><process version="9.6.000">
<context>
<input/>
<output/>
<macros/>
</context>
<operator activated="true" class="process" compatibility="9.6.000" expanded="true" name="Process">
<process expanded="true">
<operator activated="true" class="generate_data" compatibility="9.6.000" expanded="true" height="68" name="Generate Data" width="90" x="45" y="34">
<parameter key="target_function" value="random"/>
<parameter key="number_examples" value="100"/>
<parameter key="number_of_attributes" value="5"/>
<parameter key="attributes_lower_bound" value="-10.0"/>
<parameter key="attributes_upper_bound" value="10.0"/>
<parameter key="gaussian_standard_deviation" value="10.0"/>
<parameter key="largest_radius" value="10.0"/>
<parameter key="use_local_random_seed" value="false"/>
<parameter key="local_random_seed" value="1992"/>
<parameter key="datamanagement" value="double_array"/>
<parameter key="data_management" value="auto"/>
<operator activated="true" class="web:enrich_data_by_webservice" compatibility="9.3.001" expanded="true" height="68" name="Enrich Data by Webservice" width="90" x="179" y="34">
<parameter key="query_type" value="Regular Expression"/>
<list key="string_machting_queries"/>
<parameter key="attribute_type" value="Nominal"/>
<list key="regular_expression_queries">
<parameter key="text" value="(.*)"/>
</list>
<list key="regular_region_queries"/>
<list key="xpath_queries"/>
<list key="namespaces"/>
<parameter key="ignore_CDATA" value="true"/>
<parameter key="assume_html" value="true"/>
<list key="index_queries"/>
<list key="jsonpath_queries">
<parameter key="entities" value="$..entities"/>
</list>
<parameter key="request_method" value="POST"/>
<parameter key="body" value="{\ 'document':{\ 'type':'PLAIN_TEXT',\ 'content':'Michelangelo Caravaggio, Italian painter, is known for\ \'The Calling of Saint Matthew\'.'\ },\ 'encodingType':'UTF8'\ }"/>
<parameter key="delay" value="0"/>
<list key="request_properties">
<parameter key="Authorization" value="Bearer ${API_KEY}"/>
<parameter key="Content-Type" value="application/json; charset=utf-8""/>
</list>
<parameter key="keep_sensitive_headers" value="true"/>
<connect from_op="Generate Data" from_port="output" to_op="Enrich Data by Webservice" to_port="Example Set"/>
<connect from_op="Enrich Data by Webservice" from_port="ExampleSet" to_port="result 1"/>
</process>
</process>
