Unable to connect to local SQL Server Express
User: "e_kraus"
New Altair Community Member
Updated by Jocelyn
I'm trying to connect to a local SQL Server Express database and followed recommendations from https://community.rapidminer.com/discussion/comment/60894
I added the "IntegratedSecurity=true" property and added the "sqljdbc_auth.dll" library on the driver tab.
My URL is jdbc:sqlserver://localhost:1433;databaseName=Crash2019
and I'm getting the error message
"The TCP/IP connection to the host localhost, port 1433 has failed. Error: "Connection refused: connect. Verify the connection properties. Make sure that an instance of SQL Server is running on the host and accepting TCP/IP connections at the port. Make sure that TCP connections to the port are not blocked by a firewall."
1 - 1 of 11
