<?xml version="1.0" encoding="UTF-8"?><process version="9.6.000"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="9.6.000" expanded="true" name="Process"> <parameter key="logverbosity" value="init"/> <parameter key="random_seed" value="2001"/> <parameter key="send_mail" value="never"/> <parameter key="notification_email" value=""/> <parameter key="process_duration_for_mail" value="30"/> <parameter key="encoding" value="SYSTEM"/> <process expanded="true"> <operator activated="true" class="retrieve" compatibility="9.6.000" expanded="true" height="68" name="Retrieve Sonar" width="90" x="45" y="34"> <parameter key="repository_entry" value="//Samples/data/Sonar"/> </operator> <operator activated="true" class="principal_component_analysis" compatibility="9.6.000" expanded="true" height="103" name="PCA" width="90" x="246" y="85"> <parameter key="dimensionality_reduction" value="keep variance"/> <parameter key="variance_threshold" value="0.95"/> <parameter key="number_of_components" value="1"/> </operator> <operator activated="true" class="converters:pca_2_example_set" compatibility="0.6.000" expanded="true" height="82" name="PCA Result to ExampleSet" width="90" x="380" y="187"/> <connect from_op="Retrieve Sonar" from_port="output" to_op="PCA" to_port="example set input"/> <connect from_op="PCA" from_port="example set output" to_port="result 1"/> <connect from_op="PCA" from_port="preprocessing model" to_op="PCA Result to ExampleSet" to_port="pca"/> <connect from_op="PCA Result to ExampleSet" from_port="exa" to_port="result 2"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> <portSpacing port="sink_result 3" spacing="0"/> </process> </operator> </process>
