I am doing a simple market basket analysis example using the famous bakery data set. The data comes in as integer, I convert it to binomial and then run FP-growth, which works fine. I wanted to see zeros and ones in the example, not true or false, and I used the Map operator to change it. It did not work.
Here is the process:
<?xml version="1.0" encoding="UTF-8"?><process version="9.6.000">
<context>
<input/>
<output/>
<macros/>
</context>
<operator activated="true" class="process" compatibility="9.6.000" expanded="true" name="Process">
<process expanded="true">
<operator activated="true" class="retrieve" compatibility="9.6.000" expanded="true" height="68" name="Retrieve Bakery5000-out2" width="90" x="45" y="34">
<parameter key="repository_entry" value="../../data/Bakery5000-out2"/>
<operator activated="true" class="numerical_to_binominal" compatibility="9.6.000" expanded="true" height="82" name="Numerical to Binominal" width="90" x="45" y="136">
<parameter key="attribute_filter_type" value="all"/>
<parameter key="attribute" value=""/>
<parameter key="value_type" value="numeric"/>
<parameter key="except_value_type" value="real"/>
<parameter key="block_type" value="value_series"/>
<parameter key="except_block_type" value="value_series_end"/>
<parameter key="min" value="0.0"/>
<parameter key="max" value="0.0"/>
<operator activated="true" class="map" compatibility="9.6.000" expanded="true" height="82" name="Map" width="90" x="112" y="238">
<list key="value_mappings">
<parameter key="true" value="1"/>
<parameter key="false" value="0"/>
</list>
<parameter key="consider_regular_expressions" value="false"/>
<parameter key="add_default_mapping" value="false"/>
<operator activated="true" class="concurrency:fp_growth" compatibility="9.6.000" expanded="true" height="82" name="FP-Growth" width="90" x="313" y="289">
<parameter key="input_format" value="items in dummy coded columns"/>
<parameter key="item_separators" value="|"/>
<parameter key="use_quotes" value="false"/>
<parameter key="quotes_character" value="""/>
<parameter key="escape_character" value="\"/>
<parameter key="trim_item_names" value="true"/>
<parameter key="positive_value" value="true"/>
<parameter key="min_requirement" value="support"/>
<parameter key="min_support" value="0.005"/>
<parameter key="min_frequency" value="100"/>
<parameter key="min_items_per_itemset" value="1"/>
<parameter key="max_items_per_itemset" value="0"/>
<parameter key="max_number_of_itemsets" value="1000000"/>
<parameter key="find_min_number_of_itemsets" value="true"/>
<parameter key="min_number_of_itemsets" value="100"/>
<parameter key="max_number_of_retries" value="15"/>
<parameter key="requirement_decrease_factor" value="0.9"/>
<enumeration key="must_contain_list"/>
<operator activated="true" class="create_association_rules" compatibility="9.6.000" expanded="true" height="82" name="Create Association Rules" width="90" x="447" y="85">
<parameter key="criterion" value="lift"/>
<parameter key="min_confidence" value="0.9"/>
<parameter key="min_criterion_value" value="2.0"/>
<parameter key="gain_theta" value="2.0"/>
<parameter key="laplace_k" value="1.0"/>
<connect from_op="Retrieve Bakery5000-out2" from_port="output" to_op="Numerical to Binominal" to_port="example set input"/>
<connect from_op="Numerical to Binominal" from_port="example set output" to_op="Map" to_port="example set input"/>
<connect from_op="Map" from_port="example set output" to_op="FP-Growth" to_port="example set"/>
<connect from_op="FP-Growth" from_port="example set" to_port="result 3"/>
<connect from_op="FP-Growth" from_port="frequent sets" to_op="Create Association Rules" to_port="item sets"/>
<connect from_op="Create Association Rules" from_port="rules" to_port="result 1"/>
<connect from_op="Create Association Rules" from_port="item sets" to_port="result 2"/>
</process>
</process>
