<?xml version="1.0" encoding="UTF-8"?><process version="9.6.000"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="9.6.000" expanded="true" name="Process"> <parameter key="logverbosity" value="init"/> <parameter key="random_seed" value="2001"/> <parameter key="send_mail" value="never"/> <parameter key="notification_email" value=""/> <parameter key="process_duration_for_mail" value="30"/> <parameter key="encoding" value="SYSTEM"/> <process expanded="true"> <operator activated="true" class="generate_data" compatibility="9.6.000" expanded="true" height="68" name="Generate Data" width="90" x="581" y="34"> <parameter key="target_function" value="random"/> <parameter key="number_examples" value="100"/> <parameter key="number_of_attributes" value="5"/> <parameter key="attributes_lower_bound" value="-10.0"/> <parameter key="attributes_upper_bound" value="10.0"/> <parameter key="gaussian_standard_deviation" value="10.0"/> <parameter key="largest_radius" value="10.0"/> <parameter key="use_local_random_seed" value="false"/> <parameter key="local_random_seed" value="1992"/> <parameter key="datamanagement" value="double_array"/> <parameter key="data_management" value="auto"/> </operator> <operator activated="true" breakpoints="after" class="rename" compatibility="9.6.000" expanded="true" height="82" name="Rename" width="90" x="715" y="34"> <parameter key="old_name" value="att1"/> <parameter key="new_name" value="count (prod_name)_sunglasses"/> <list key="rename_additional_attributes"> <parameter key="att2" value="count (prod_name)_rayban"/> </list> </operator> <operator activated="true" class="subprocess" compatibility="9.6.000" expanded="true" height="82" name="Rename by replacing block" width="90" x="916" y="34"> <process expanded="true"> <operator activated="true" class="rename_by_replacing" compatibility="9.6.000" expanded="true" height="82" name="Rename by Replacing" width="90" x="45" y="34"> <parameter key="attribute_filter_type" value="subset"/> <parameter key="attribute" value=""/> <parameter key="attributes" value="count (prod_name)_rayban|count (prod_name)_sunglasses"/> <parameter key="use_except_expression" value="false"/> <parameter key="value_type" value="attribute_value"/> <parameter key="use_value_type_exception" value="false"/> <parameter key="except_value_type" value="time"/> <parameter key="block_type" value="attribute_block"/> <parameter key="use_block_type_exception" value="false"/> <parameter key="except_block_type" value="value_matrix_row_start"/> <parameter key="invert_selection" value="false"/> <parameter key="include_special_attributes" value="false"/> <parameter key="replace_what" value="count"/> <parameter key="replace_by" value=""/> </operator> <operator activated="true" class="rename_by_replacing" compatibility="9.6.000" expanded="true" height="82" name="Rename by Replacing (2)" width="90" x="179" y="34"> <parameter key="attribute_filter_type" value="subset"/> <parameter key="attribute" value=""/> <parameter key="attributes" value=" (prod_name)_rayban| (prod_name)_sunglasses"/> <parameter key="use_except_expression" value="false"/> <parameter key="value_type" value="attribute_value"/> <parameter key="use_value_type_exception" value="false"/> <parameter key="except_value_type" value="time"/> <parameter key="block_type" value="attribute_block"/> <parameter key="use_block_type_exception" value="false"/> <parameter key="except_block_type" value="value_matrix_row_start"/> <parameter key="invert_selection" value="false"/> <parameter key="include_special_attributes" value="false"/> <parameter key="replace_what" value="[_()]"/> <parameter key="replace_by" value=""/> </operator> <operator activated="true" class="rename_by_replacing" compatibility="9.6.000" expanded="true" height="82" name="Rename by Replacing (3)" width="90" x="313" y="34"> <parameter key="attribute_filter_type" value="subset"/> <parameter key="attribute" value=""/> <parameter key="attributes" value=" prodnamerayban| prodnamesunglasses"/> <parameter key="use_except_expression" value="false"/> <parameter key="value_type" value="attribute_value"/> <parameter key="use_value_type_exception" value="false"/> <parameter key="except_value_type" value="time"/> <parameter key="block_type" value="attribute_block"/> <parameter key="use_block_type_exception" value="false"/> <parameter key="except_block_type" value="value_matrix_row_start"/> <parameter key="invert_selection" value="false"/> <parameter key="include_special_attributes" value="false"/> <parameter key="replace_what" value="prodname"/> </operator> <connect from_port="in 1" to_op="Rename by Replacing" to_port="example set input"/> <connect from_op="Rename by Replacing" from_port="example set output" to_op="Rename by Replacing (2)" to_port="example set input"/> <connect from_op="Rename by Replacing (2)" from_port="example set output" to_op="Rename by Replacing (3)" to_port="example set input"/> <connect from_op="Rename by Replacing (3)" from_port="example set output" to_port="out 1"/> <portSpacing port="source_in 1" spacing="0"/> <portSpacing port="source_in 2" spacing="0"/> <portSpacing port="sink_out 1" spacing="0"/> <portSpacing port="sink_out 2" spacing="0"/> </process> </operator> <connect from_op="Generate Data" from_port="output" to_op="Rename" to_port="example set input"/> <connect from_op="Rename" from_port="example set output" to_op="Rename by replacing block" to_port="in 1"/> <connect from_op="Rename by replacing block" from_port="out 1" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator> </process>
.*\((\w+)\)
$1
