<?xml version="1.0" encoding="UTF-8"?><process version="9.6.000"><br> <context><br> <input/><br> <output/><br> <macros/><br> </context><br> <operator activated="true" class="process" compatibility="9.6.000" expanded="true" name="Process"><br> <parameter key="logverbosity" value="init"/><br> <parameter key="random_seed" value="2001"/><br> <parameter key="send_mail" value="never"/><br> <parameter key="notification_email" value=""/><br> <parameter key="process_duration_for_mail" value="30"/><br> <parameter key="encoding" value="SYSTEM"/><br> <process expanded="true"><br> <operator activated="true" class="retrieve" compatibility="9.6.000" expanded="true" height="68" name="Retrieve Prices of Gas Station" width="90" x="45" y="187"><br> <parameter key="repository_entry" value="//Samples/Time Series/data sets/Prices of Gas Station"/><br> </operator><br> <operator activated="true" class="time_series:windowing" compatibility="9.6.000" expanded="true" height="82" name="Windowing" width="90" x="179" y="187"><br> <parameter key="attribute_filter_type" value="single"/><br> <parameter key="attribute" value="gas price / euro (times 1000)"/><br> <parameter key="attributes" value=""/><br> <parameter key="use_except_expression" value="false"/><br> <parameter key="value_type" value="attribute_value"/><br> <parameter key="use_value_type_exception" value="false"/><br> <parameter key="except_value_type" value="time"/><br> <parameter key="block_type" value="attribute_block"/><br> <parameter key="use_block_type_exception" value="false"/><br> <parameter key="except_block_type" value="value_matrix_row_start"/><br> <parameter key="invert_selection" value="false"/><br> <parameter key="include_special_attributes" value="false"/><br> <parameter key="has_indices" value="true"/><br> <parameter key="indices_attribute" value="date"/><br> <parameter key="window_size" value="24"/><br> <parameter key="no_overlapping_windows" value="false"/><br> <parameter key="step_size" value="1"/><br> <parameter key="create_horizon_(labels)" value="true"/><br> <parameter key="horizon_attribute" value="gas price / euro (times 1000)"/><br> <parameter key="horizon_size" value="6"/><br> <parameter key="horizon_offset" value="0"/><br> <description align="center" color="transparent" colored="false" width="126">Horizon Size is 6, so we forecast the next 6h<br/></description><br> </operator><br> <operator activated="true" class="filter_examples" compatibility="9.6.000" expanded="true" height="103" name="Filter Examples" width="90" x="313" y="187"><br> <parameter key="parameter_expression" value=""/><br> <parameter key="condition_class" value="custom_filters"/><br> <parameter key="invert_filter" value="false"/><br> <list key="filters_list"><br> <parameter key="filters_entry_key" value="Last date in window.lt.01/01/2018 00:00:00 AM"/><br> </list><br> <parameter key="filters_logic_and" value="true"/><br> <parameter key="filters_check_metadata" value="true"/><br> <description align="center" color="transparent" colored="false" width="126">simple split validation</description><br> </operator><br> <operator activated="true" class="time_series:multi_horizon_forecast_learner" compatibility="9.6.000" expanded="true" height="82" name="Multi Horizon Forecast" width="90" x="514" y="85"><br> <parameter key="use_default_regular_expression" value="true"/><br> <parameter key="add_macros" value="false"/><br> <parameter key="current_horizon_name_macro" value="current_horizon_attribute"/><br> <parameter key="current_horizon_type_macro" value="current_horizon_type"/><br> <parameter key="enable_parallel_execution" value="true"/><br> <process expanded="true"><br> <operator activated="true" class="h2o:generalized_linear_model" compatibility="9.3.001" expanded="true" height="124" name="Generalized Linear Model (2)" width="90" x="45" y="34"><br> <parameter key="family" value="AUTO"/><br> <parameter key="link" value="family_default"/><br> <parameter key="solver" value="AUTO"/><br> <parameter key="reproducible" value="false"/><br> <parameter key="maximum_number_of_threads" value="4"/><br> <parameter key="use_regularization" value="true"/><br> <parameter key="lambda_search" value="false"/><br> <parameter key="number_of_lambdas" value="0"/><br> <parameter key="lambda_min_ratio" value="0.0"/><br> <parameter key="early_stopping" value="true"/><br> <parameter key="stopping_rounds" value="3"/><br> <parameter key="stopping_tolerance" value="0.001"/><br> <parameter key="standardize" value="true"/><br> <parameter key="non-negative_coefficients" value="false"/><br> <parameter key="add_intercept" value="true"/><br> <parameter key="compute_p-values" value="false"/><br> <parameter key="remove_collinear_columns" value="false"/><br> <parameter key="missing_values_handling" value="MeanImputation"/><br> <parameter key="max_iterations" value="0"/><br> <parameter key="specify_beta_constraints" value="false"/><br> <list key="beta_constraints"/><br> <parameter key="max_runtime_seconds" value="0"/><br> <list key="expert_parameters"/><br> </operator><br> <connect from_port="training set" to_op="Generalized Linear Model (2)" to_port="training set"/><br> <connect from_op="Generalized Linear Model (2)" from_port="model" to_port="model"/><br> <portSpacing port="source_training set" spacing="0"/><br> <portSpacing port="source_input 1" spacing="0"/><br> <portSpacing port="sink_model" spacing="0"/><br> <portSpacing port="sink_output 1" spacing="0"/><br> </process><br> </operator><br> <operator activated="true" class="apply_model" compatibility="9.6.000" expanded="true" height="82" name="Apply Model" width="90" x="648" y="238"><br> <list key="application_parameters"/><br> <parameter key="create_view" value="false"/><br> </operator><br> <operator activated="true" class="time_series:multi_label_performance_evaluator" compatibility="9.6.000" expanded="true" height="124" name="Multi Label Performance" width="90" x="782" y="34"><br> <parameter key="auto_detect_label_and_prediction_attributes" value="true"/><br> <parameter key="attribute_filter_type" value="all"/><br> <parameter key="attribute" value=""/><br> <parameter key="attributes" value=""/><br> <parameter key="use_except_expression" value="false"/><br> <parameter key="value_type" value="attribute_value"/><br> <parameter key="use_value_type_exception" value="false"/><br> <parameter key="except_value_type" value="time"/><br> <parameter key="block_type" value="attribute_block"/><br> <parameter key="use_block_type_exception" value="false"/><br> <parameter key="except_block_type" value="value_matrix_row_start"/><br> <parameter key="invert_selection" value="false"/><br> <parameter key="include_special_attributes" value="true"/><br> <parameter key="add_macros" value="false"/><br> <parameter key="current_label_name_macro" value="current_label_attribute"/><br> <parameter key="current_label_type_macro" value="current_label_type"/><br> <parameter key="enable_parallel_execution" value="true"/><br> <process expanded="true"><br> <operator activated="true" class="performance_regression" compatibility="9.6.000" expanded="true" height="82" name="Performance" width="90" x="179" y="34"><br> <parameter key="main_criterion" value="first"/><br> <parameter key="root_mean_squared_error" value="true"/><br> <parameter key="absolute_error" value="true"/><br> <parameter key="relative_error" value="true"/><br> <parameter key="relative_error_lenient" value="false"/><br> <parameter key="relative_error_strict" value="false"/><br> <parameter key="normalized_absolute_error" value="false"/><br> <parameter key="root_relative_squared_error" value="false"/><br> <parameter key="squared_error" value="false"/><br> <parameter key="correlation" value="false"/><br> <parameter key="squared_correlation" value="false"/><br> <parameter key="prediction_average" value="false"/><br> <parameter key="spearman_rho" value="false"/><br> <parameter key="kendall_tau" value="false"/><br> <parameter key="skip_undefined_labels" value="true"/><br> <parameter key="use_example_weights" value="true"/><br> </operator><br> <connect from_port="labelled set" to_op="Performance" to_port="labelled data"/><br> <connect from_op="Performance" from_port="performance" to_port="performance"/><br> <portSpacing port="source_labelled set" spacing="0"/><br> <portSpacing port="source_input 1" spacing="0"/><br> <portSpacing port="sink_performance" spacing="0"/><br> <portSpacing port="sink_output 1" spacing="0"/><br> </process><br> </operator><br> <connect from_op="Retrieve Prices of Gas Station" from_port="output" to_op="Windowing" to_port="example set"/><br> <connect from_op="Windowing" from_port="windowed example set" to_op="Filter Examples" to_port="example set input"/><br> <connect from_op="Filter Examples" from_port="example set output" to_op="Multi Horizon Forecast" to_port="training set"/><br> <connect from_op="Filter Examples" from_port="unmatched example set" to_op="Apply Model" to_port="unlabelled data"/><br> <connect from_op="Multi Horizon Forecast" from_port="model" to_op="Apply Model" to_port="model"/><br> <connect from_op="Apply Model" from_port="labelled data" to_op="Multi Label Performance" to_port="labelled set"/><br> <connect from_op="Apply Model" from_port="model" to_port="result 3"/><br> <connect from_op="Multi Label Performance" from_port="collection of performances" to_port="result 1"/><br> <connect from_op="Multi Label Performance" from_port="performance" to_port="result 2"/><br> <portSpacing port="source_input 1" spacing="0"/><br> <portSpacing port="sink_result 1" spacing="0"/><br> <portSpacing port="sink_result 2" spacing="42"/><br> <portSpacing port="sink_result 3" spacing="105"/><br> <portSpacing port="sink_result 4" spacing="0"/><br> </process><br> </operator><br></process><br><br>
