how to convert column data into comma separated values
sgnarkhede2016
Hello All,
I want to convert my column data in to comma separated values,
e.g.
I have one column
Name
Sachin,
Amit
Om
John
I want output like Sachin,Amit,Om,John
How to do this in rapidminer
MartinLiebig
You can use Aggregate with concat as aggregation function. After wards you need to Replace the | with , . See attached example.
Best,
Martin
<?xml version="1.0" encoding="UTF-8"?><process version="9.6.000">
<context>
<input/>
<output/>
<macros/>
</context>
<operator activated="true" class="process" compatibility="9.6.000" expanded="true" name="Process">
<process expanded="true">
<operator activated="true" class="utility:create_exampleset" compatibility="9.6.000" expanded="true" height="68" name="Create ExampleSet" width="90" x="45" y="136">
<parameter key="generator_type" value="comma separated text"/>
<parameter key="number_of_examples" value="100"/>
<parameter key="use_stepsize" value="false"/>
<list key="function_descriptions"/>
<parameter key="add_id_attribute" value="false"/>
<list key="numeric_series_configuration"/>
<list key="date_series_configuration"/>
<list key="date_series_configuration (interval)"/>
<parameter key="date_format" value="yyyy-MM-dd HH:mm:ss"/>
<parameter key="time_zone" value="SYSTEM"/>
<parameter key="input_csv_text" value="Name Sachin Amit Om John "/>
<parameter key="column_separator" value=";"/>
<parameter key="parse_all_as_nominal" value="false"/>
<parameter key="decimal_point_character" value="."/>
<parameter key="trim_attribute_names" value="true"/>
<operator activated="true" class="aggregate" compatibility="9.6.000" expanded="true" height="82" name="Aggregate" width="90" x="179" y="136">
<parameter key="use_default_aggregation" value="false"/>
<parameter key="attribute_filter_type" value="all"/>
<parameter key="attribute" value=""/>
<parameter key="default_aggregation_function" value="average"/>
<parameter key="Name" value="concatenation"/>
</list>
<parameter key="group_by_attributes" value=""/>
<parameter key="count_all_combinations" value="false"/>
<parameter key="only_distinct" value="false"/>
<parameter key="ignore_missings" value="true"/>
<operator activated="true" class="replace" compatibility="9.6.000" expanded="true" height="82" name="Replace" width="90" x="313" y="136">
<parameter key="value_type" value="nominal"/>
<parameter key="except_value_type" value="file_path"/>
<parameter key="block_type" value="single_value"/>
<parameter key="except_block_type" value="single_value"/>
<parameter key="replace_what" value="\|"/>
<parameter key="replace_by" value=","/>
<connect from_op="Create ExampleSet" from_port="output" to_op="Aggregate" to_port="example set input"/>
<connect from_op="Aggregate" from_port="example set output" to_op="Replace" to_port="example set input"/>
<connect from_op="Replace" from_port="example set output" to_port="result 1"/>
</process>
</process>
MartinLiebig
Best,
Martin
<context>
<input/>
<output/>
<macros/>
</context>
</list>
</process>
</process>
sgnarkhede2016
thanks
