<?xml version="1.0" encoding="UTF-8"?><process version="9.6.000"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="9.6.000" expanded="true" name="Process"> <parameter key="logverbosity" value="init"/> <parameter key="random_seed" value="2001"/> <parameter key="send_mail" value="never"/> <parameter key="notification_email" value=""/> <parameter key="process_duration_for_mail" value="30"/> <parameter key="encoding" value="SYSTEM"/> <process expanded="true"> <operator activated="true" class="cloud_connectivity:read_amazons3" compatibility="9.3.000" expanded="true" height="82" name="Read Amazon S3" width="90" x="112" y="34"> <parameter key="connection_source" value="repository"/> <parameter key="connection_entry" value="//Local Repository/Connections/s3"/> <parameter key="file" value="s3file"/> </operator> <connect from_op="Read Amazon S3" from_port="file" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator> </process>
