I have two attributes: "Data" with binomial values "Y" and "N", and "Predicted" with real values between 0 and 1. I want to apply a threshold to the "Predicted" attribute to convert it into binomial values, then test its accuracy against the "Data" attribute.
to use the operator "Apply Threshold", I had to make two real confidence attributes, "confidence(Y)" and "confidence(N)" (values set to "Predicted" and 1 - "Predicted") with roles by the same names, and a binomial "pred" attribute with role "prediction" (values initially copied from "Data").
however, when I run the process, it replaces each value of "pred" to "N", regardless of whether "confidence(positive)" was greater than the threshold. that suggests to me that "Apply Threshold" is failing to read the "confidence(positive)" attribute, but I don't know why or how to fix it.
<?xml version="1.0" encoding="UTF-8"?><process version="9.6.000">
<context>
<input/>
<output/>
<macros/>
</context>
<operator activated="true" class="process" compatibility="9.6.000" expanded="true" name="Process">
<process expanded="true">
<operator activated="true" class="create_threshold" compatibility="9.6.000" expanded="true" height="68" name="Create Threshold" width="90" x="581" y="340">
<parameter key="threshold" value="0.5"/>
<parameter key="first_class" value="N"/>
<parameter key="second_class" value="Y"/>
<operator activated="true" class="utility:create_exampleset" compatibility="9.6.000" expanded="true" height="68" name="Create ExampleSet" width="90" x="45" y="238">
<parameter key="generator_type" value="comma separated text"/>
<parameter key="number_of_examples" value="100"/>
<parameter key="use_stepsize" value="false"/>
<list key="function_descriptions"/>
<parameter key="add_id_attribute" value="false"/>
<list key="numeric_series_configuration"/>
<list key="date_series_configuration"/>
<list key="date_series_configuration (interval)"/>
<parameter key="date_format" value="yyyy-MM-dd HH:mm:ss"/>
<parameter key="time_zone" value="SYSTEM"/>
<parameter key="input_csv_text" value="Data,Predicted (Model) Y,0.225135637 N,0.015354609 N,0.0001 Y,0.417204888 N,0.0001 Y,0.825845697 Y,0.566671094 N,0.361344126 Y,0.138533613 N,0.0001 N,0.0001 N,0.10015621 N,0.519371562 Y,0.687709876 Y,0.488898237 Y,0.471409091 N,0.118468641 Y,0.373571663 N,0.0001 N,0.078786849 N,0.067795272 Y,0.421387476 Y,0.83791151 N,0.0001 Y,0.457122298 N,0.405682588 Y,0.580764825 Y,0.218196512 Y,0.655224335 Y,0.855784984 Y,0.50579238 Y,0.084138364 N,0.0001 Y,0.821532224 Y,0.678781002 Y,0.926816559 N,0.50659274 N,0.164581177 Y,0.328660268 Y,0.288377542 N,0.059794767 Y,0.62206104 N,0.064220637 Y,0.791833862 Y,0.207360705 Y,0.34374656 Y,0.225577433 Y,0.75455163 Y,0.506957704 N,0.0001 N,0.058930078 Y,0.749783305 N,0.03936428 Y,0.850028134 N,0.172089154 N,0.066416753 Y,0.567490629 N,0.057332485 Y,0.761940543 N,0.125667186 Y,0.678991758 N,0.228706155 Y,0.68499118 N,0.09513121 Y,0.351269244 Y,0.570312751 N,0.0001 Y,0.138407109 N,0.439762099 N,0.200565587 N,0.0001 N,0.133003815 Y,0.404646644 Y,0.550891144 Y,0.415110029 Y,0.42737024 Y,0.175065829 N,0.38808125 Y,0.570520642 Y,0.6173936 N,0.0001 N,0.223786655 Y,0.245724872 N,0.147310984 Y,0.656746637 N,0.136984071 Y,0.694440361 N,0.403283901 Y,0.253220092 Y,0.587039158 N,0.096477247 Y,0.77295129 N,0.081595909 Y,0.138402045 Y,0.372460544 N,0.036575703 Y,0.278538797 Y,0.729871568 Y,0.544152042 Y,0.8140683 N,0.108877327 N,0.0001 N,0.0001 N,0.140347197 N,0.0001 N,0.111951146 N,0.273102486 Y,0.746288955 Y,0.280770148 Y,0.441145204 Y,0.194084087 Y,0.300068795 Y,0.881620015 Y,0.44164248 N,0.0001 N,0.227901755 N,0.2157731 Y,0.652973156 N,0.361191701 N,0.0001 Y,0.544357267 N,0.216806743 Y,0.663144573 N,0.390221372 N,0.0001 N,0.017205352 N,0.046550353 Y,0.497414924 Y,0.375995967 N,0.211114841 N,0.0001 Y,0.338798002 Y,0.758031735 N,0.364765878 N,0.172331655 Y,0.490027205 N,0.384078322 Y,0.149516671 N,0.008708927 Y,0.224359365 Y,0.674530153 Y,0.473461694 Y,0.232653724 N,0.171596763 Y,0.661383153 Y,0.476280739 N,0.188372312 Y,0.660643742 Y,0.560021217 Y,0.498866655 N,0.417782676 N,0.0001 Y,0.396102307 Y,0.392494 N,0.067356851 Y,0.506465866 Y,0.741886036 Y,0.493834563 Y,0.622761886 Y,0.778629673 N,0.376177326 N,0.0001 Y,0.094023964 Y,0.411875357 N,0.0001 Y,0.656660618 Y,0.358468475 N,0.150609275 N,0.0001 Y,0.614080059 N,0.0001 N,0.0001 N,0.0001 N,0.0001 N,0.107406666 Y,0.236991851 Y,0.569899753 Y,0.465197292 N,0.293648623 N,0.314567095 N,0.0879467 Y,0.454703781 Y,0.444991643 N,0.050408819 Y,0.437551851 N,0.130305697 Y,0.336272424 Y,0.592396667 Y,0.138354142 N,0.0001 Y,0.834161136 N,0.023170873 Y,0.323113794 N,0.211781092 N,0.444532586 Y,0.443579097 N,0.0001 N,0.139058433 N,0.0001 N,0.0001 Y,0.38499674 N,0.0001 N,0.0001 Y,0.123681638 Y,0.472032978 N,0.525912484 N,0.0001 Y,0.396940427 N,0.26437863 Y,0.016477121 N,0.0001 N,0.082716598 N,0.0001 Y,0.783494732 N,0.109288479 N,0.157626045 N,0.236647676 Y,0.740077106 N,0.0001 N,0.0001 N,0.206587293 N,0.0001 N,0.0001 Y,0.577468692 Y,0.421772481 Y,0.762127968 N,0.0001 Y,0.530366393 N,0.24857274 N,0.435365668 N,0.0001 Y,0.506477522 Y,0.191485506 Y,0.804013908 N,0.0001 N,0.096306717 Y,0.767580687 Y,0.425041496 Y,0.652461621 Y,0.589906399 N,0.0001 Y,0.643446801 N,0.259075579 N,0.0001 Y,0.673050019 Y,0.082421867 N,0.099447465 Y,0.579345273 N,0.0001 N,0.057514014 Y,0.461871654 Y,0.689637808 N,0.0001 Y,0.406664727 N,0.0001 N,0.569201064 N,0.228117263 Y,0.458958547 N,0.282189415 Y,0.715746041 Y,0.369831765 Y,0.311177796 N,0.0001 Y,0.437475655 N,0.0001 N,0.0001 Y,0.906274537 N,0.0001 N,0.133111991 Y,0.669950473 Y,0.519887446 N,0.0001 N,0.0001 N,0.117140248 Y,0.712497054 Y,0.893230805 Y,0.494572867 Y,0.299682746 N,0.0001 N,0.0001 Y,0.499195639 Y,0.615206839 N,0.0001 Y,0.136910848 N,0.014205447 Y,0.529345336 N,0.0001 Y,0.251291365 N,0.0001 Y,0.55477882 N,0.0001 Y,0.426870088 N,0.0001 Y,0.731543209 N,0.0001 Y,0.374157588 Y,0.528718106 N,0.0001 Y,0.56013638 N,0.072086761 Y,0.14616557 Y,0.620443499 N,0.16173902 Y,0.863615019 Y,0.575539093 N,0.0001 Y,0.369297454 Y,0.306617238 Y,0.487022496 N,0.103230158 Y,0.421359953 N,0.0001 Y,0.466354069 N,0.0001 Y,0.343187848 Y,0.289559068 N,0.2598892 N,0.139309321 N,0.0001 N,0.0001 Y,0.756972227 Y,0.120890758 N,0.197729503 N,0.003897131 Y,0.416436328 N,0.012402934 N,0.0001 Y,0.715699273 Y,0.675610616 Y,0.76506855 N,0.0001 Y,0.740078389 Y,0.841420838 Y,0.946896945 N,0.321274399 N,0.0001 N,0.27794159 Y,0.627639721 N,0.0001 N,0.249467153 N,0.547360596 Y,0.247236577 N,0.133425249 N,0.370176607 N,0.0001 Y,0.328332491 N,0.256813811 N,0.0001 Y,0.290020592 N,0.0001 N,0.167306727 Y,0.461690135 N,0.0001 N,0.013979646 Y,0.38813855 N,0.0001 N,0.310334236 N,0.079071151 Y,0.303275331 N,0.213885215 Y,0.393860182 Y,0.756254078 N,0.431842777 N,0.0001 Y,0.654117607 N,0.0001 Y,0.672115813 N,0.0001 N,0.0001 Y,0.545970153 Y,0.21624029 Y,0.483109475 Y,0.650828347 Y,0.569211719 N,0.0001 N,0.049746375 Y,0.355987251 N,0.0001 Y,0.299716127 Y,0.433379057 N,0.237669631 Y,0.537777033 Y,0.414516654 Y,0.800943762 N,0.296561107 Y,0.307934951 Y,0.64754962 N,0.103993581 N,0.019950852 Y,0.564411487 N,0.226002456 N,0.134567234 N,0.116892748 N,0.087493619 N,0.0001 N,0.0001 Y,0.481522363 Y,0.197206406 N,0.0001 N,0.0001 Y,0.357638592 N,0.339037244 N,0.003120399 Y,0.947301575 N,0.0001 Y,0.784902692 N,0.044356782 N,0.0001 N,0.0001 N,0.0001 N,0.374658095 N,0.012133725 N,0.2948613 N,0.251805187 Y,0.645569376 N,0.0001 N,0.0001 Y,0.751735992 Y,0.853200073 N,0.0001 Y,0.610057866 Y,0.205791168 Y,0.410984321 N,0.0001 Y,0.240038325 N,0.038818104 Y,0.232435184 N,0.102906186 N,0.0001 Y,0.569323556 N,0.037841539 Y,0.414147987 N,0.0001 Y,0.236093926 N,0.0001 Y,0.236813976 Y,0.514436048 N,0.0001 N,0.553110218 N,0.209966555 N,0.310611491 N,0.152955599 N,0.0001 N,0.327167013 N,0.0001 Y,0.30384918 Y,0.4794465 Y,0.529956575 N,0.0001 N,0.0001 Y,0.432274926 Y,0.616129736 N,0.0001 N,0.253718861 Y,0.407991737 N,0.033500072 N,0.0001 N,0.0001 N,0.122598716 Y,0.462312565 Y,0.636183238 N,0.15793286 Y,0.525098812 Y,0.664147094 N,0.119070125 N,0.0001 Y,0.392602571 Y,0.614612375 N,0.0001 Y,0.616730864 Y,0.608618551 Y,0.669451092 N,0.0001 N,0.235920685 Y,0.480602525 Y,0.635614226 Y,0.391854656 N,0.0001 Y,0.171784877 N,0.204082013 N,0.0001 Y,0.382701189 N,0.170276811 N,0.46742213 N,0.0001 N,0.219946765 Y,0.440881918 Y,0.449594655 N,0.0001 Y,0.71216168 Y,0.419952203 N,0.0001 N,0.139149903 Y,0.455097673 Y,0.882282519 N,0.0001 N,0.0001 Y,0.505806915 Y,0.902558123 N,0.0001 Y,0.695310694 N,0.0001 N,0.0001 N,0.0001 N,0.0001 Y,0.272600363 N,0.082621314 Y,0.464395827 Y,0.618428958 N,0.534692101 N,0.317367673 N,0.0001 Y,0.442227556 N,0.312675623 N,0.0001 Y,0.48229638 N,0.022550871 N,0.332781055 Y,0.261599822 N,0.171541869 N,0.0001 Y,0.657273788 N,0.349638823 Y,0.728735209 N,0.0001 N,0.105249134 Y,0.293894261 N,0.072273469 Y,0.354570915 Y,0.410064204 Y,0.44739504 N,0.027614561 Y,0.881784332 Y,0.459467358 N,0.304315326 Y,0.922627318 Y,0.488731015 N,0.08180952 N,0.0001 Y,0.431488904 N,0.0001 Y,0.322131287 N,0.0001 Y,0.458514891 N,0.303006734 Y,0.267055728 Y,0.451880527 N,0.0001 Y,0.476867183 N,0.338357589 Y,0.49317765 N,0.0001 N,0.137388967 N,0.0001 N,0.419280027 N,0.0001 N,0.0001 Y,0.365977923 Y,0.683814368 N,0.104229766 Y,0.266574586 N,0.0001 Y,0.473696875 N,0.0001 Y,0.845870623 Y,0.485531138 N,0.029826583 N,0.222998412 Y,0.323085626 Y,0.143263659 N,0.065829181 N,0.509900073 N,0.218699182 Y,0.128101281 Y,0.66981003 Y,0.406257409 Y,0.588944898 N,0.0001 N,0.0001 Y,0.399266965 N,0.0001 Y,0.548846566 Y,0.432092622 N,0.035504595 Y,0.10334879 Y,0.354320931 N,0.081648827 Y,0.278592341 Y,0.159863424 Y,0.335276015 Y,0.317995478 Y,0.224255567 N,0.0001 N,0.280176324 N,0.220114854 N,0.0001 Y,0.50654723 N,0.186054882 Y,0.736719984 Y,0.420956699 Y,0.150595767 Y,0.622305524 Y,0.551062046 Y,0.677161834 N,0.41150115 N,0.007920189 Y,0.734031477 Y,0.562884889 Y,0.471643698 N,0.0001 N,0.013878532 N,0.097310849 N,0.193405543 Y,0.857663779 N,0.293717137 N,0.087031781 N,0.157869878 Y,0.59291082 Y,0.25365872 Y,0.698096232 N,0.114082837 N,0.357157697 N,0.0001 Y,0.822196311 Y,0.253924476 N,0.087396663 N,0.21784532 Y,0.416080847 Y,0.295490847 N,0.057390894 Y,0.600339658 N,0.030259019 N,0.0001 Y,0.707060218 Y,0.397500996 Y,0.504801327 N,0.024271651 N,0.0001 N,0.0001 N,0.209848201 N,0.0001 N,0.0001 N,0.0001 N,0.04784182 N,0.278783048 Y,0.476560849 N,0.249272095 N,0.046025145 Y,0.786108381 N,0.058610238 Y,0.485684526 N,0.0001 N,0.0001 N,0.080430574 Y,0.344370136 Y,0.658694756 N,0.0001 N,0.0001 Y,0.439160045 N,0.0001 Y,0.522014866 Y,0.859105664 N,0.0001 N,0.437496173 N,0.0001 N,0.0001 N,0.526884013 N,0.0001 Y,0.214610903 N,0.0001 N,0.016401764 N,0.0001 N,0.0001 N,0.241970477 Y,0.695495837 N,0.317032673 Y,0.607299397 Y,0.548803481 Y,0.33344099 Y,0.559900239 N,0.208394223 Y,0.374677024 Y,0.691080187 N,0.320086813 Y,0.711199976 N,0.194466238 N,0.233666338 Y,0.700126118 Y,0.692227304 N,0.0001 N,0.331453804 N,0.046248195 N,0.013222694 Y,0.306499687 N,0.149594568 N,0.0001 N,0.053380806 N,0.0001 N,0.0001 N,0.023008113 N,0.0001 N,0.0001 N,0.229674723 N,0.0001 N,0.0001 Y,0.321182671 Y,0.428749642 Y,0.566150251 N,0.0001 Y,0.511773068 Y,0.596826633 Y,0.823276811 N,0.524878327 Y,0.386924324 Y,0.747610463 N,0.190618533 Y,0.460864335 Y,0.785706276 Y,0.459875204 N,0.0001 N,0.254958384 Y,0.185463342 N,0.035334286 N,0.075808253 Y,0.854482472 Y,0.914284326 Y,0.212628439 Y,0.265490188 N,0.0001 N,0.0001 N,0.0001 N,0.295387804 N,0.405498812 N,0.0001 N,0.0001 N,0.0001 N,0.0001 Y,0.611449556 N,0.526792533 N,0.0001 N,0.133207602 N,0.0001 N,0.0001 Y,0.300581865 Y,0.158833098 N,0.005364351 Y,0.62159008 Y,0.453849922 N,0.187174104 Y,0.866807928 Y,0.806227147 N,0.0001 Y,0.362711419 Y,0.43583843 N,0.0001 Y,0.602603798 Y,0.663746571 N,0.199855035 Y,0.722291116 Y,0.406066934 N,0.331255266 N,0.104007554 Y,0.765300649 Y,0.209248341 N,0.0001 N,0.121066031 N,0.03341763 N,0.0001 Y,0.610553932 N,0.0001 N,0.052303161 N,0.077363827 Y,0.405943411 N,0.065796284 N,0.162271252 N,0.169449634 N,0.0001 Y,0.779449556 Y,0.19624205 N,0.294631095 N,0.291751597 N,0.0001 N,0.0001 N,0.013072464 Y,0.517111032 N,0.0001 Y,0.365286909 Y,0.46479032 Y,0.230558948 Y,0.417642527 Y,0.449738427 Y,0.264059427 Y,0.695118223 N,0.090090211 N,0.154512044 N,0.039469784 N,0.0001 N,0.0001 Y,0.735186954 Y,0.256441841 Y,0.106400168 N,0.165173342 Y,0.53432136 Y,0.642590241 Y,0.493018827 Y,0.70583896 N,0.0001 N,0.202781829 Y,0.971718293 N,0.0001 N,0.0001 Y,0.418778437 N,0.0001 N,0.169709239 N,0.0001 Y,0.769994131 Y,0.5753103 N,0.232768014 Y,0.133646896 Y,0.553130877 Y,0.279022074 Y,0.751445026 Y,0.421113498 N,0.0001 Y,0.487873541 N,0.03316964 Y,0.451994726 N,0.158025789 Y,0.454016039 N,0.0001 N,0.0001 Y,0.472813314 Y,0.527048191 Y,0.947359869 N,0.0001 Y,0.729952878 N,0.0001 Y,0.712574396 N,0.0001 N,0.250259731 N,0.0001 N,0.174528678 N,0.0001 Y,0.318162899 Y,0.197255877 Y,0.439948842 N,0.0001 Y,0.151991212 Y,0.422560972 Y,0.403602741 Y,0.851536446 N,0.0001 Y,0.312774584 Y,0.500420116 N,0.24236253 Y,0.766122181 Y,0.683882082 N,0.0001 Y,0.33215044 N,0.135521792 Y,0.729956278 N,0.375581592 Y,0.224688697 Y,0.12008483 Y,0.612192195 Y,0.726500396 Y,0.554846858 Y,0.138862007 Y,0.498733144 Y,0.133926581 N,0.019771907 N,0.0001 N,0.0001 Y,0.418526176 N,0.0001 Y,0.693800082 Y,0.094795326 Y,0.925085811 N,0.15195066 Y,0.788710019 N,0.0001 N,0.0001 N,0.297479909 Y,0.290528007 Y,0.601438588 N,0.0001 Y,0.353469645 Y,0.408118578 Y,0.538191918 Y,0.253631898 N,0.0001 Y,0.526085645 N,0.0001 Y,0.460109653 Y,0.775072288 N,0.0001 Y,0.489153238 N,0.0001 N,0.0001 N,0.034608624 Y,0.411143627 Y,0.403309021 Y,0.690479379 Y,0.58645295 Y,0.703471435 N,0.240645419 N,0.317348965 N,0.0001 N,0.0001 Y,0.479985015 N,0.051663453 N,0.151098679 Y,0.400885126 Y,0.669478979 N,0.0001 N,0.084509219 N,0.104969007 N,0.202747595 N,0.0001 Y,0.248550676 Y,0.736360718 Y,0.507362049 Y,0.45185447 N,0.170658129 N,0.0001 Y,0.492524913 Y,0.863828983 Y,0.505563511 Y,0.855626349 Y,0.214503677 Y,0.667043014 N,0.04338791 N,0.268321785 N,0.163068649 N,0.032860214 Y,0.432603468 N,0.050831568 Y,0.282183637 Y,0.497255402 Y,0.507714476 N,0.048046271 N,0.302599739 Y,0.552843342 N,0.0001 N,0.0001 N,0.045763161 N,0.0001 Y,0.35923354 Y,0.275079272 Y,0.490030294 N,0.093214431 Y,0.33982672 Y,0.228286029 N,0.173078966 N,0.24842934 N,0.0001 Y,0.215257771 N,0.10263881 Y,0.609961692 Y,0.153339016 N,0.040604182 N,0.0001 Y,0.420378131 N,0.035050649 N,0.0001 Y,0.956775757 N,0.312246201 N,0.0001 Y,0.619621516 N,0.062474506 Y,0.83682199 N,0.0001 N,0.0001 N,0.087984095 Y,0.513109824 Y,0.168519626 N,0.0001 N,0.0125382 Y,0.623915238 N,0.299362197 Y,0.700795017 Y,0.639515816 N,0.0001 Y,0.423247208 Y,0.314171344 N,0.0001 Y,0.675042884 Y,0.858816065 N,0.0001 N,0.262590264 N,0.107755031 Y,0.642963514 Y,0.684925359 Y,0.439486907 Y,0.474113532 Y,0.248236629 Y,0.573986919 N,0.015263223 Y,0.65455098 Y,0.699771428"/>
<parameter key="column_separator" value=","/>
<parameter key="parse_all_as_nominal" value="false"/>
<parameter key="decimal_point_character" value="."/>
<parameter key="trim_attribute_names" value="true"/>
<operator activated="true" class="generate_attributes" compatibility="9.6.000" expanded="true" height="82" name="Generate Attributes" width="90" x="179" y="238">
<parameter key="pred" value="Data"/>
<parameter key="confidence(N)" value="1-[Predicted (Model)]"/>
<parameter key="confidence(Y)" value="[Predicted (Model)]"/>
</list>
<parameter key="keep_all" value="true"/>
<operator activated="true" class="nominal_to_binominal" compatibility="9.6.000" expanded="true" height="103" name="Nominal to Binominal" width="90" x="313" y="238">
<parameter key="return_preprocessing_model" value="false"/>
<parameter key="create_view" value="false"/>
<parameter key="attribute" value="pred"/>
<parameter key="value_type" value="nominal"/>
<parameter key="except_value_type" value="file_path"/>
<parameter key="block_type" value="single_value"/>
<parameter key="except_block_type" value="single_value"/>
<parameter key="transform_binominal" value="false"/>
<parameter key="use_underscore_in_name" value="false"/>
<operator activated="true" class="set_role" compatibility="9.6.000" expanded="true" height="82" name="Set Role" width="90" x="447" y="238">
<parameter key="attribute_name" value="Data"/>
<list key="set_additional_roles">
<parameter key="pred" value="prediction"/>
<parameter key="confidence(N)" value="confidence(N)"/>
<parameter key="confidence(Y)" value="confidence(Y)"/>
</list>
<operator activated="true" class="select_attributes" compatibility="9.6.000" expanded="true" height="82" name="Select Attributes" width="90" x="581" y="238">
<parameter key="attribute" value="Predicted (Model)"/>
<operator activated="true" breakpoints="before" class="apply_threshold" compatibility="9.6.000" expanded="true" height="82" name="Apply Threshold" width="90" x="715" y="238"/>
<connect from_op="Create Threshold" from_port="output" to_op="Apply Threshold" to_port="threshold"/>
<connect from_op="Create ExampleSet" from_port="output" to_op="Generate Attributes" to_port="example set input"/>
<connect from_op="Generate Attributes" from_port="example set output" to_op="Nominal to Binominal" to_port="example set input"/>
<connect from_op="Nominal to Binominal" from_port="example set output" to_op="Set Role" to_port="example set input"/>
<connect from_op="Set Role" from_port="example set output" to_op="Select Attributes" to_port="example set input"/>
<connect from_op="Select Attributes" from_port="example set output" to_op="Apply Threshold" to_port="example set"/>
<connect from_op="Apply Threshold" from_port="example set" to_port="result 1"/>
</process>
</process>
<br>
