I intended to see the displacement of the pink and yellow component.
I intended to apply loading condition like this: the downward (or compressive) loading is represented by RBE3 elements that are connected to all nodes on the upper flat surface. The bottom flat surface is constrained in all 6 DOF.
I want to assume that between the outer and inner cylinder are glued like one body but with different material properties (so I want the light blue and darker blue to be glued, as well as yellow and pink to be glued). I also want to assume that there are friction between the blue-yellow and light blue-pink components, with the friction coefficient of 0.3.
Therefore, I would like to ask, what kind of analysis that I can apply? Besides, how can I define which contact to which components?
I've heard that frictional contact analysis is always nonlinear analysis. But I am sorry I am still not used to know which control cards or contact-related functions in Hyperworks and Hypermesh.
In this model as well, the meshes on the interfaces across all different models are well connected. Would that affect in choosing the analysis? I've seen other solver used node-to-surface or surface-to-surface approximation as part of its contact analysis formula, as their examples show that there are gaps between two contacting parts.
