adding labels to a polynominal variable
Mori111
I have a polynominal variable, Income, with 4 categories: <25, 25-49, 50-75. 75+. I want to add a label to each category. For example, for <25, I want to add (or replace it with) a label " Low Income". What is the simplest way to add labels to a polynominal variable?
David_A
Hi
@Mori111
you can easily rename/replace your categories with other values by using the
Replace
operator.
To specify an attribute as label, you can use the
Set Role
operator and select "label" as target role. Be aware that each example set can only has one attribute marked as "label".
Best,
David
sgenzer
@Mori111
yes as
@David_A
said, 'Replace' will work. So will the 'Map' operator. Or you can do it in Turbo Prep.
Mori111
Great Thanks. MAP operator works better because at the same time you can replace all values with labels. I haven't tested Turbo Prep yet.
