Test model for different outcome variable
aksaha
I have rapidminer deep learning predictive model for a output variable, I want to see how to the model performs to a different outcome variable using the same learning information. What would be the best operator to use ?
Thanks
sgenzer
hi
@aksaha
I'm not sure exactly what you mean here. Do you want to rebuild the model with a new predicted class, or do you want to score the model on new data with the same predicted class? The latter is easy - just use Apply Model. The former is not hard either - just use Set Role to set a new predicted class and build the model again.
Does that help?
Scott
varunm1
Hello
@aksaha
If you are looking to predict multiple label columns, which I think you are trying to do. You need to use a "Multi-label modeling" operator. You can see the tutorial in that operator "help" window.
Note: Multi-label modeling creates multiple models based on the number of outcome variables (attributes) you are trying to predict.
Generally, a model trained for one outcome variable will support prediction for that variable. If you are looking for "transfer learning" then I am not sure if rapidminer supports that.
If you are trying to predict the same label column for new data, then
@sgenzer
suggestion works
