I have problem in defining the elements that I want to insert in the matrix browser. According to tutorials, there should be "Query" button on the lower right hand corner of matrix browser. But in my Hyperworks it disappears. I would appreciate any advice, thank you.
My suggestion is to close any open Altair software and then run the following file to delete the temporary files.
C:\Program Files\Altair\2021.2\hwdesktop\utility\HWCleanup
This is probably related to your screen resolution.
It should be in the bttom, as you've mentioned. But depending on your screen resolution and size, it might be hidden.
Can you try undocking the matrix browser? (by dragging it out from the browser area)
