ensemble learning
Thiru
I tried a data set with ensemble learning (using KNN, decision tree, Naïve bayes). Im not able to see any improvement in the accuracy/precision/recall.
1. Is there any way to view the performance of individual models while using ensemble learning. - to compare the performance of the individual as well as ensemble in a single process.
2. when I use generate weight option - there is a warning for Knn - sub model , saying
" input example set has example weights, but learner will ignore them"
. Even if we say -the learner ignores, the accuracy still reduces. First of all what is that warning coming
only for Knn
and its impact?
thanks
thiru
BalazsBaranyRM
Hi
@Thiru
you can do a Cross-Validation inside the ensemble model. You can use the Remember operator to store the individual performance results, or even store them into the repository.
Here's an example process:
<?xml version="1.0" encoding="UTF-8"?><process version="9.5.001">
<context>
<input/>
<output/>
<macros/>
</context>
<operator activated="true" class="process" compatibility="9.5.001" expanded="true" name="Process">
<parameter key="random_seed" value="-1"/>
<process expanded="true">
<operator activated="true" class="retrieve" compatibility="9.5.001" expanded="true" height="68" name="Retrieve Iris" width="90" x="112" y="34">
<parameter key="repository_entry" value="//Samples/data/Iris"/>
<operator activated="true" class="generate_weight_stratification" compatibility="9.5.001" expanded="true" height="82" name="Generate Weight (Stratification)" width="90" x="246" y="34">
<parameter key="total_weight" value="1.0"/>
<operator activated="true" class="concurrency:cross_validation" compatibility="9.5.001" expanded="true" height="145" name="Validation" width="90" x="380" y="34">
<parameter key="split_on_batch_attribute" value="false"/>
<parameter key="leave_one_out" value="false"/>
<parameter key="number_of_folds" value="10"/>
<parameter key="sampling_type" value="stratified sampling"/>
<parameter key="use_local_random_seed" value="false"/>
<parameter key="local_random_seed" value="1992"/>
<parameter key="enable_parallel_execution" value="true"/>
<operator activated="true" class="vote" compatibility="9.5.001" expanded="true" height="68" name="Vote" width="90" x="112" y="34">
<operator activated="true" class="concurrency:cross_validation" compatibility="9.5.001" expanded="true" height="145" name="Validation DT" width="90" x="246" y="34">
<operator activated="true" class="concurrency:parallel_decision_tree" compatibility="9.5.001" expanded="true" height="103" name="Decision Tree" width="90" x="45" y="34">
<parameter key="criterion" value="gain_ratio"/>
<parameter key="maximal_depth" value="10"/>
<parameter key="apply_pruning" value="true"/>
<parameter key="confidence" value="0.1"/>
<parameter key="apply_prepruning" value="true"/>
<parameter key="minimal_gain" value="0.01"/>
<parameter key="minimal_leaf_size" value="2"/>
<parameter key="minimal_size_for_split" value="4"/>
<parameter key="number_of_prepruning_alternatives" value="3"/>
<connect from_port="training set" to_op="Decision Tree" to_port="training set"/>
<connect from_op="Decision Tree" from_port="model" to_port="model"/>
<portSpacing port="source_training set" spacing="0"/>
<description align="left" color="green" colored="true" height="80" resized="false" width="248" x="37" y="158">In the training phase, a model is built on the current training data set. (90 % of data by default, 10 times)</description>
</process>
<operator activated="true" class="apply_model" compatibility="9.5.001" expanded="true" height="82" name="Apply Model" width="90" x="45" y="34">
<parameter key="create_view" value="false"/>
<operator activated="true" class="performance" compatibility="9.5.001" expanded="true" height="82" name="Performance (DT)" width="90" x="179" y="34">
<parameter key="use_example_weights" value="true"/>
<connect from_port="model" to_op="Apply Model" to_port="model"/>
<connect from_port="test set" to_op="Apply Model" to_port="unlabelled data"/>
<connect from_op="Apply Model" from_port="labelled data" to_op="Performance (DT)" to_port="labelled data"/>
<connect from_op="Performance (DT)" from_port="performance" to_port="performance 1"/>
<connect from_op="Performance (DT)" from_port="example set" to_port="test set results"/>
<portSpacing port="sink_test set results" spacing="0"/>
<portSpacing port="sink_performance 1" spacing="0"/>
<portSpacing port="sink_performance 2" spacing="0"/>
<description align="left" color="blue" colored="true" height="103" resized="false" width="315" x="38" y="158">The model created in the Training step is applied to the current test set (10 %).<br/>The performance is evaluated and sent to the operator results.</description>
</process>
<operator activated="true" class="remember" compatibility="9.5.001" expanded="true" height="68" name="Remember DTResults" width="90" x="447" y="85">
<parameter key="name" value="DTResults"/>
<parameter key="io_object" value="PerformanceVector"/>
<parameter key="store_which" value="1"/>
<parameter key="remove_from_process" value="true"/>
<operator activated="true" class="concurrency:cross_validation" compatibility="9.5.001" expanded="true" height="145" name="Validation k-NN" width="90" x="112" y="187">
<operator activated="true" class="k_nn" compatibility="9.5.001" expanded="true" height="82" name="k-NN" width="90" x="112" y="34">
<parameter key="k" value="5"/>
<parameter key="weighted_vote" value="true"/>
<parameter key="measure_types" value="MixedMeasures"/>
<parameter key="mixed_measure" value="MixedEuclideanDistance"/>
<parameter key="nominal_measure" value="NominalDistance"/>
<parameter key="numerical_measure" value="EuclideanDistance"/>
<parameter key="divergence" value="GeneralizedIDivergence"/>
<parameter key="kernel_type" value="radial"/>
<parameter key="kernel_gamma" value="1.0"/>
<parameter key="kernel_sigma1" value="1.0"/>
<parameter key="kernel_sigma2" value="0.0"/>
<parameter key="kernel_sigma3" value="2.0"/>
<parameter key="kernel_degree" value="3.0"/>
<parameter key="kernel_shift" value="1.0"/>
<parameter key="kernel_a" value="1.0"/>
<parameter key="kernel_b" value="0.0"/>
<connect from_port="training set" to_op="k-NN" to_port="training set"/>
<connect from_op="k-NN" from_port="model" to_port="model"/>
</process>
<operator activated="true" class="apply_model" compatibility="9.5.001" expanded="true" height="82" name="Apply Model (2)" width="90" x="45" y="34">
<operator activated="true" class="performance" compatibility="9.5.001" expanded="true" height="82" name="Performance (k-NN)" width="90" x="179" y="34">
<connect from_port="model" to_op="Apply Model (2)" to_port="model"/>
<connect from_port="test set" to_op="Apply Model (2)" to_port="unlabelled data"/>
<connect from_op="Apply Model (2)" from_port="labelled data" to_op="Performance (k-NN)" to_port="labelled data"/>
<connect from_op="Performance (k-NN)" from_port="performance" to_port="performance 1"/>
<connect from_op="Performance (k-NN)" from_port="example set" to_port="test set results"/>
</process>
<operator activated="true" class="remember" compatibility="9.5.001" expanded="true" height="68" name="Remember k-NN results" width="90" x="447" y="238">
<parameter key="name" value="kNNResults"/>
<operator activated="true" class="concurrency:cross_validation" compatibility="9.5.001" expanded="true" height="145" name="Validation Naive Bayes" width="90" x="246" y="340">
<operator activated="true" class="naive_bayes" compatibility="9.5.001" expanded="true" height="82" name="Naive Bayes" width="90" x="112" y="34">
<parameter key="laplace_correction" value="true"/>
<connect from_port="training set" to_op="Naive Bayes" to_port="training set"/>
<connect from_op="Naive Bayes" from_port="model" to_port="model"/>
</process>
<operator activated="true" class="apply_model" compatibility="9.5.001" expanded="true" height="82" name="Apply Model (3)" width="90" x="45" y="34">
<operator activated="true" class="performance" compatibility="9.5.001" expanded="true" height="82" name="Performance (Naive Bayes)" width="90" x="179" y="34">
<connect from_port="model" to_op="Apply Model (3)" to_port="model"/>
<connect from_port="test set" to_op="Apply Model (3)" to_port="unlabelled data"/>
<connect from_op="Apply Model (3)" from_port="labelled data" to_op="Performance (Naive Bayes)" to_port="labelled data"/>
<connect from_op="Performance (Naive Bayes)" from_port="performance" to_port="performance 1"/>
<connect from_op="Performance (Naive Bayes)" from_port="example set" to_port="test set results"/>
</process>
<operator activated="true" class="remember" compatibility="9.5.001" expanded="true" height="68" name="Remember Bayes results" width="90" x="447" y="391">
<parameter key="name" value="NaiveBayesResults"/>
<connect from_port="training set 1" to_op="Validation DT" to_port="example set"/>
<connect from_port="training set 2" to_op="Validation k-NN" to_port="example set"/>
<connect from_port="training set 3" to_op="Validation Naive Bayes" to_port="example set"/>
<connect from_op="Validation DT" from_port="model" to_port="base model 1"/>
<connect from_op="Validation DT" from_port="performance 1" to_op="Remember DTResults" to_port="store"/>
<connect from_op="Validation k-NN" from_port="model" to_port="base model 2"/>
<connect from_op="Validation k-NN" from_port="performance 1" to_op="Remember k-NN results" to_port="store"/>
<connect from_op="Validation Naive Bayes" from_port="performance 1" to_op="Remember Bayes results" to_port="store"/>
<portSpacing port="source_training set 1" spacing="0"/>
<portSpacing port="source_training set 2" spacing="0"/>
<portSpacing port="source_training set 3" spacing="0"/>
<portSpacing port="source_training set 4" spacing="0"/>
<portSpacing port="sink_base model 1" spacing="0"/>
<portSpacing port="sink_base model 2" spacing="0"/>
<portSpacing port="sink_base model 3" spacing="0"/>
</process>
<connect from_port="training set" to_op="Vote" to_port="training set"/>
<connect from_op="Vote" from_port="model" to_port="model"/>
<description align="left" color="green" colored="true" height="80" resized="true" width="248" x="37" y="158">In the training phase, a model is built on the current training data set. (90 % of data by default, 10 times)</description>
</process>
<operator activated="true" class="apply_model" compatibility="9.5.001" expanded="true" height="82" name="Apply Model (4)" width="90" x="45" y="34">
<operator activated="true" class="performance" compatibility="9.5.001" expanded="true" height="82" name="Performance (Vote)" width="90" x="179" y="34">
<connect from_port="model" to_op="Apply Model (4)" to_port="model"/>
<connect from_port="test set" to_op="Apply Model (4)" to_port="unlabelled data"/>
<connect from_op="Apply Model (4)" from_port="labelled data" to_op="Performance (Vote)" to_port="labelled data"/>
<connect from_op="Performance (Vote)" from_port="performance" to_port="performance 1"/>
<connect from_op="Performance (Vote)" from_port="example set" to_port="test set results"/>
<description align="left" color="blue" colored="true" height="103" resized="true" width="315" x="38" y="158">The model created in the Training step is applied to the current test set (10 %).<br/>The performance is evaluated and sent to the operator results.</description>
</process>
<operator activated="true" class="recall" compatibility="9.5.001" expanded="true" height="68" name="Recall Decision Tree" width="90" x="581" y="136">
<parameter key="remove_from_store" value="true"/>
<operator activated="true" class="recall" compatibility="9.5.001" expanded="true" height="68" name="Recall k-NN" width="90" x="648" y="238">
<operator activated="true" class="recall" compatibility="9.5.001" expanded="true" height="68" name="Recall Naive Bayes" width="90" x="715" y="340">
<connect from_op="Retrieve Iris" from_port="output" to_op="Generate Weight (Stratification)" to_port="example set input"/>
<connect from_op="Generate Weight (Stratification)" from_port="example set output" to_op="Validation" to_port="example set"/>
<connect from_op="Validation" from_port="model" to_port="result 1"/>
<connect from_op="Validation" from_port="performance 1" to_port="result 2"/>
<connect from_op="Recall Decision Tree" from_port="result" to_port="result 3"/>
<connect from_op="Recall k-NN" from_port="result" to_port="result 4"/>
<connect from_op="Recall Naive Bayes" from_port="result" to_port="result 5"/>
<portSpacing port="sink_result 3" spacing="42"/>
<portSpacing port="sink_result 4" spacing="105"/>
<portSpacing port="sink_result 5" spacing="63"/>
<portSpacing port="sink_result 6" spacing="0"/>
</process>
</process>
The warning is somewhat unexpected, as k-NN is being used for explaining example weighting on Academy:
https://academy.rapidminer.com/learn/video/sampling-weighting-intro
@jmergler
@Knut-RM
The impact is: If you use example weighting to make some examples more important (e. g. minority class, or customers with a high revenue), you expect the models to make more effort in predicting these examples correctly. If the model is good and catches these examples correctly anyway, you won't see a big impact.
@mbs
: No, Group Models won't help here. The output of the first model is a model. If you put a second model into it, it will complain because it expects an Example Set as its input.
Balázs
[Deleted User]
@Thiru
Hello
you can use Group model operator. This operator groups the given models into a single combined model. When this combined model is applied, it is equivalent to applying the original models in their respective order.
and you can use this link:
https://community.rapidminer.com/discussion/comment/61377#Comment_61377
All the best
mbs
BalazsBaranyRM
Hi
@Thiru
<context>
<input/>
<output/>
<macros/>
</context>
</process>
</process>
</process>
</process>
</process>
</process>
</process>
</process>
</process>
</process>
</process>
@jmergler
@Knut-RM
@mbs
Balázs
[Deleted User]
@BalazsBarany
Hello
Thank you for your help
that was the problem of document
https://docs.rapidminer.com/latest/studio/operators/rapidminer-studio-operator-reference.pdf
@sgenzer
please look in Group model part in pdf
Regards
mbs
Jeff_Mergler
Great discussion! Thanks
@BalazsBarany
for calling my attention to it. Yes, k-NN has it's own variable weighting scheme and example weighting will be ignored with that operator; if you are using an ensemble method like voting then the other learners will still use the example weighting. However, in the current training, the lecture portion shows k-NN with example weighting. Then the demo process we have uses a decision tree which does handle weighted examples. We'll work to improve the lecture!
