sequences
[Deleted User]
Hello
Look at this chart please, can RM analyze sequence of images like this? ( each square has an image and they have a sequence like matrix)
Thank you in advance
mbs
rfuentealba
Hello
@mbs
I would definitely take a look at imagemagick to process the images (resize, cut, etc...), put these into folders and use some more magic to transform the image into something texty.
ImageMagick is a command line tool you can invoke with the Execute Program operator.
Hope this helps,
Rod.
rfuentealba
I can.
Well... basically all images are
glorified
sets of numbers. I can make an icon with the German flag with something like this:
(0,0,0) (0,0,0) (0,0,0)
(221,0,0) (221,0,0) (221,0,0)
(255,206,0) (255,206,0) (255,206,0)
Most analyses as neural networks, however, don't make use of a matrix. Instead, a neural network (I'm not entering into details about convolutional neural networks here) asks for an input like this:
(0,0,0) (0,0,0) (0,0,0) (221,0,0) (221,0,0) (221,0,0) (255,206,0) (255,206,0) (255,206,0)
Therefore if by "sequence" you mean "how much are images changed", then I would invent something with time series and the set of numbers or something similar. (This is just an invention).
This means that RapidMiner
can
analyse images but it all depends on what do you need to do with these. The thing is that RapidMiner doesn't have a way to import/export images as content, to the best of my knowledge at least, so you need to decode those into numbers, probably using Python or something that can help you do the destructive part.
All the best,
Rod.
Telcontar120
If this is image processing, then probably you would need to do something with the Deep Learning extension and putting together different layers for taking the windowing as shown in the diagram.
[Deleted User]
@Telcontar120
Thank you for the answer.
yes exactly but the problem is sequences!!!! can RM read that like matrix?
Regards
mbs
Telcontar120
I am definitely not an expert in the capabilities of the current DL extension.
@pschlunder
is probably better positioned to answer your question.
[Deleted User]
For this project I have a lot of images ( like previous screen shot), what is your suggestion for gathering all of them in one place to make a data base?
thank you
rfuentealba
Hello
@mbs
Hope this helps,
Rod.
[Deleted User]
@rfuentealba
hi
thank you very much for the answer
can you tell me about the first question too?
rfuentealba
I can.
glorified
can
All the best,
Rod.
[Deleted User]
@rfuentealba
thank you great answer
pschlunder
I would not necessarily store images in a data base but rather on disk. Typically you keep them in folders, where the name represents the label.
RapidMiner can interpret a flattened matrix as such. You can uncheck the "Infer input shape" option on the Deep Learning operator and set the shape to "Convolutional Flattened".
If you need to process sequential data like you're asking for, you can create an example set where the batch column identifies the sequence and an id column where each id value identifies the step in the current batch. For batch and id columns use the given special roles with the "Set Role" operator.
You're data could look like this:
Where batch = 1 is one sequence with 10 sequence entries/steps/images and att1 to att5 could be your flattened image vector like
@rfuentealba
nicely explained.
If your data is in that format convert it to a tensor using the "ExampleSet to Tensor" operator of the Deep Learning extension (available since version 0.9.3) and create your network inside the "Deep Learning on Tensor" operator.
Hope this helps,
Philipp
