"Impute Missing Value" example set is empty
pablo_199
im running a basic titanic data cleansing, and im trying to fill the na's of the cabin column with the impute missing value operator. i insert the missing values as input, i can even visualize them if i dragg to result, but once i connect it to Impute Missing Value, it says the example set is empty, could anyone help
varunm1
Hello
@pablo_199
The issue in your process is that you are selecting a single attribute that has missing values in "impute missing values" operator. This doesn't work as the KNN needs predictor attributes to learn and impute missing values in a column. For this purpose, I selected all attributes. Once more issue is with filter examples before impute missing values, this will get only examples with missing value columns. The issue here is KNN doesn't have a clue what it needs to place in "Cabin" column as all the values in that column are missing due to this filter. I removed that.
Please find attached .rmp file. To run this go to File __> Import Process and point it to the file location you download into PC. Please let us know if you have any questions.
Modified_Process.rmp
pablo_199
varunm1
Hello
@pablo_199
Can you post your process by exporting using FILE --> Export process and attach the process here?
We will check it.
Thanks
Varun
pablo_199
sorry, the correct process is the one named so, ignore the previous one
correctProccess.rmp
pablo_199
Hello
@varunm1
thanks for your reply, i have added the proccess now
thanks in advance for the help
varunm1
Hello
@pablo_199
Thanks, Can you provide dataset as well? I thought you used titanic from Rapidminer samples, but its unable to retrieve.
I also see that the screenshot you mentioned earlier doesn't match with the current process you provided. The "impute missing values" operator is missing in the attached process.
lionelderkrikor
Hi
@pablo_199
, Hi
@varunm1
According the error "example set is empty", It seems that the
Filter examples
operator is filtering all the examples. (the condition
missing attributes
seems to be always true)
I think you don't need to add this operator for the task you want to aschieve (
"trying to fill the na's of the cabin column").
Try to remove
Filter Examples
operator...
But I agree with Varun : Can you please share your data in order we can run your process ?
Thanks and regards,
Lionel
pablo_199
hi
@varunm1
@lionelderkrikor
yes i submitted a wrong proccess and since i couldn`t erase it i added the right one. ill attach the dataset now, i tried both erasing the operator and adding it but the error remains the same. i want to thank you for the time in attempting to help me
varunm1
Hello
@pablo_199
