<?xml version="1.0" encoding="UTF-8"?><process version="9.5.001"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="9.5.001" expanded="true" name="Process"> <parameter key="logverbosity" value="init"/> <parameter key="random_seed" value="2001"/> <parameter key="send_mail" value="never"/> <parameter key="notification_email" value=""/> <parameter key="process_duration_for_mail" value="30"/> <parameter key="encoding" value="SYSTEM"/> <process expanded="true"> <operator activated="true" class="read_excel" compatibility="9.5.001" expanded="true" height="68" name="Read Excel" width="90" x="45" y="34"> <parameter key="excel_file" value="example.xlsx"/> <parameter key="sheet_selection" value="sheet number"/> <parameter key="sheet_number" value="1"/> <parameter key="imported_cell_range" value="A1"/> <parameter key="encoding" value="SYSTEM"/> <parameter key="first_row_as_names" value="true"/> <list key="annotations"/> <parameter key="date_format" value=""/> <parameter key="time_zone" value="SYSTEM"/> <parameter key="locale" value="English (United States)"/> <parameter key="read_all_values_as_polynominal" value="false"/> <list key="data_set_meta_data_information"> <parameter key="0" value="A.true.integer.attribute"/> <parameter key="1" value="B.true.integer.attribute"/> <parameter key="2" value="C.true.integer.attribute"/> <parameter key="3" value="D.true.integer.attribute"/> <parameter key="4" value="E.true.integer.attribute"/> <parameter key="5" value="year.true.integer.attribute"/> <parameter key="6" value="week.true.integer.attribute"/> <parameter key="7" value="air.true.real.attribute"/> <parameter key="8" value="mmp.true.real.attribute"/> <parameter key="9" value="total.true.integer.attribute"/> <parameter key="10" value="total+1.true.integer.attribute"/> <parameter key="11" value="label_A+1.true.integer.attribute"/> <parameter key="12" value="label_B+1.true.integer.attribute"/> <parameter key="13" value="label_C+1.true.integer.attribute"/> <parameter key="14" value="label_D+1.true.integer.attribute"/> <parameter key="15" value="label_E+1.true.integer.attribute"/> <parameter key="16" value="total-1.true.integer.attribute"/> <parameter key="17" value="total-2.true.integer.attribute"/> <parameter key="18" value="total-3.true.integer.attribute"/> <parameter key="19" value="A-1.true.integer.attribute"/> <parameter key="20" value="A-2.true.integer.attribute"/> <parameter key="21" value="A-3.true.integer.attribute"/> <parameter key="22" value="B-1.true.integer.attribute"/> <parameter key="23" value="B-2.true.integer.attribute"/> <parameter key="24" value="B-3.true.integer.attribute"/> <parameter key="25" value="C-1.true.integer.attribute"/> <parameter key="26" value="C-2.true.integer.attribute"/> <parameter key="27" value="C-3.true.integer.attribute"/> <parameter key="28" value="D-1.true.integer.attribute"/> <parameter key="29" value="D-2.true.integer.attribute"/> <parameter key="30" value="D-3.true.integer.attribute"/> <parameter key="31" value="E-1.true.integer.attribute"/> <parameter key="32" value="E-2.true.integer.attribute"/> <parameter key="33" value="E-3.true.integer.attribute"/> <parameter key="34" value="id.true.integer.attribute"/> </list> <parameter key="read_not_matching_values_as_missings" value="false"/> <parameter key="datamanagement" value="double_array"/> <parameter key="data_management" value="auto"/> </operator> <operator activated="true" class="set_role" compatibility="9.5.001" expanded="true" height="82" name="Set Role" width="90" x="179" y="34"> <parameter key="attribute_name" value="label_A+1"/> <parameter key="target_role" value="label"/> <list key="set_additional_roles"/> </operator> <operator activated="true" class="vector_linear_regression" compatibility="9.5.001" expanded="true" height="82" name="Vector Linear Regression" width="90" x="313" y="34"> <parameter key="use_bias" value="true"/> <parameter key="ridge" value="1.0E-8"/> </operator> <operator activated="true" class="apply_model" compatibility="9.5.001" expanded="true" height="82" name="Apply Model" width="90" x="447" y="34"> <list key="application_parameters"/> <parameter key="create_view" value="false"/> </operator> <connect from_op="Read Excel" from_port="output" to_op="Set Role" to_port="example set input"/> <connect from_op="Set Role" from_port="example set output" to_op="Vector Linear Regression" to_port="training set"/> <connect from_op="Vector Linear Regression" from_port="model" to_op="Apply Model" to_port="model"/> <connect from_op="Vector Linear Regression" from_port="exampleSet" to_op="Apply Model" to_port="unlabelled data"/> <connect from_op="Apply Model" from_port="labelled data" to_port="result 2"/> <connect from_op="Apply Model" from_port="model" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> <portSpacing port="sink_result 3" spacing="0"/> </process> </operator> </process>
