LDAEvaluationWordNet - wrong connection
Ka13n
Ka13n New Altair Community Member
Dear all
I am new to the community and also new to this field, I apologize for the dumb questions in advanced.
I am trying to run LDAEvaluationWordNet for my text mining data. However, it always shows that '' Your connection is producing the wrong type of data.......''. (Refer the XML code)
Can someone help me with that? Thank you! :smiley:
<?xml version="1.0" encoding="UTF-8"?><process version="9.5.001">
  <context>
    <input/>
    <output/>
    <macros/>
  </context>
  <operator activated="true" class="process" compatibility="6.0.002" expanded="true" name="Process">
    <process expanded="true">
      <operator activated="true" class="concurrency:loop_files" compatibility="9.5.001" expanded="true" height="82" name="Loop Files (2)" width="90" x="112" y="34">
        <parameter key="directory" value="C:\Users\Kevin\Desktop\REF PDF"/>
        <parameter key="filter_type" value="regex"/>
        <parameter key="filter_by_regex" value=".*.pdf"/>
        <parameter key="recursive" value="false"/>
        <parameter key="enable_macros" value="true"/>
        <parameter key="macro_for_file_name" value="file_name"/>
        <parameter key="macro_for_file_type" value="file_type"/>
        <parameter key="macro_for_folder_name" value="folder_name"/>
        <parameter key="reuse_results" value="false"/>
        <parameter key="enable_parallel_execution" value="true"/>
          <operator activated="true" class="text:read_document" compatibility="8.2.000" expanded="true" height="68" name="Read Document" width="90" x="45" y="34">
            <parameter key="extract_text_only" value="true"/>
            <parameter key="use_file_extension_as_type" value="true"/>
            <parameter key="content_type" value="pdf"/>
          <operator activated="true" class="text:process_documents" compatibility="8.2.000" expanded="true" height="103" name="Process Documents" width="90" x="246" y="34">
            <parameter key="create_word_vector" value="true"/>
            <parameter key="vector_creation" value="TF-IDF"/>
            <parameter key="add_meta_information" value="true"/>
            <parameter key="keep_text" value="false"/>
            <parameter key="prune_method" value="none"/>
            <parameter key="prune_below_percent" value="3.0"/>
            <parameter key="prune_above_percent" value="30.0"/>
            <parameter key="prune_below_absolute" value="2"/>
            <parameter key="prune_above_absolute" value="9999"/>
            <parameter key="prune_below_rank" value="5.0"/>
            <parameter key="prune_above_rank" value="5.0"/>
            <parameter key="datamanagement" value="double_sparse_array"/>
            <parameter key="data_management" value="auto"/>
              <operator activated="true" class="text:tokenize" compatibility="8.2.000" expanded="true" height="68" name="Tokenize" width="90" x="179" y="136">
                <parameter key="mode" value="non letters"/>
                <parameter key="characters" value=".:"/>
                <parameter key="language" value="English"/>
                <parameter key="max_token_length" value="3"/>
              <operator activated="true" class="text:stem_porter" compatibility="8.2.000" expanded="true" height="68" name="Stem (Porter)" width="90" x="447" y="136"/>
              <operator activated="true" class="text:filter_stopwords_english" compatibility="8.2.000" expanded="true" height="68" name="Filter Stopwords (English)" width="90" x="648" y="136"/>
              <connect from_port="document" to_op="Tokenize" to_port="document"/>
              <connect from_op="Tokenize" from_port="document" to_op="Stem (Porter)" to_port="document"/>
              <connect from_op="Stem (Porter)" from_port="document" to_op="Filter Stopwords (English)" to_port="document"/>
              <connect from_op="Filter Stopwords (English)" from_port="document" to_port="document 1"/>
            </process>
          <operator activated="true" class="text:wordlist_to_data" compatibility="8.2.000" expanded="true" height="82" name="WordList to Data" width="90" x="447" y="34"/>
          <connect from_port="file object" to_op="Read Document" to_port="file"/>
          <connect from_op="Read Document" from_port="output" to_op="Process Documents" to_port="documents 1"/>
          <connect from_op="Process Documents" from_port="word list" to_op="WordList to Data" to_port="word list"/>
          <connect from_op="WordList to Data" from_port="example set" to_port="output 1"/>
          <portSpacing port="source_file object" spacing="0"/>
          <portSpacing port="sink_output 1" spacing="0"/>
          <portSpacing port="sink_output 2" spacing="0"/>
        </process>
      <operator activated="true" class="subprocess" compatibility="9.5.001" expanded="true" height="82" name="Union Append" width="90" x="246" y="34">
          <operator activated="true" class="loop_collection" compatibility="9.5.001" expanded="true" height="82" name="Output (4)" width="90" x="45" y="34">
            <parameter key="set_iteration_macro" value="true"/>
            <parameter key="macro_name" value="iteration"/>
            <parameter key="macro_start_value" value="1"/>
            <parameter key="unfold" value="false"/>
              <operator activated="false" breakpoints="after" class="select" compatibility="9.5.001" expanded="true" height="68" name="Select (5)" width="90" x="112" y="34">
                <parameter key="index" value="%{iteration}"/>
              <operator activated="true" class="branch" compatibility="9.5.001" expanded="true" height="82" name="Branch (2)" width="90" x="313" y="34">
                <parameter key="condition_type" value="expression"/>
                <parameter key="expression" value="%{iteration}==1"/>
                <parameter key="io_object" value="ANOVAMatrix"/>
                <parameter key="return_inner_output" value="true"/>
                  <connect from_port="condition" to_port="input 1"/>
                  <portSpacing port="source_condition" spacing="0"/>
                  <portSpacing port="sink_input 1" spacing="0"/>
                  <portSpacing port="sink_input 2" spacing="0"/>
                </process>
                  <operator activated="true" class="recall" compatibility="9.5.001" expanded="true" height="68" name="Recall (5)" width="90" x="45" y="187">
                    <parameter key="name" value="LoopData"/>
                    <parameter key="io_object" value="ExampleSet"/>
                    <parameter key="remove_from_store" value="true"/>
                  <operator activated="true" class="union" compatibility="9.5.001" expanded="true" height="82" name="Union (2)" width="90" x="179" y="34"/>
                  <connect from_port="condition" to_op="Union (2)" to_port="example set 1"/>
                  <connect from_op="Recall (5)" from_port="result" to_op="Union (2)" to_port="example set 2"/>
                  <connect from_op="Union (2)" from_port="union" to_port="input 1"/>
                </process>
              <operator activated="true" class="remember" compatibility="9.5.001" expanded="true" height="68" name="Remember (5)" width="90" x="581" y="34">
                <parameter key="store_which" value="1"/>
                <parameter key="remove_from_process" value="true"/>
              <connect from_port="single" to_op="Branch (2)" to_port="condition"/>
              <connect from_op="Branch (2)" from_port="input 1" to_op="Remember (5)" to_port="store"/>
              <connect from_op="Remember (5)" from_port="stored" to_port="output 1"/>
              <portSpacing port="source_single" spacing="0"/>
            </process>
          <operator activated="true" class="select" compatibility="9.5.001" expanded="true" height="68" name="Select (6)" width="90" x="179" y="34">
          <connect from_port="in 1" to_op="Output (4)" to_port="collection"/>
          <connect from_op="Output (4)" from_port="output 1" to_op="Select (6)" to_port="collection"/>
          <connect from_op="Select (6)" from_port="selected" to_port="out 1"/>
          <portSpacing port="source_in 2" spacing="0"/>
        </process>
      <operator activated="true" class="wordnet:open_wordnet_dictionary" compatibility="5.3.000" expanded="true" height="68" name="Open WordNet Dictionary" width="90" x="380" y="136">
        <parameter key="resource_type" value="directory"/>
        <parameter key="directory" value="C:\Users\Kevin\Desktop\WordNet-3.0\dict"/>
      <operator activated="true" class="corpus_linguistics_plugin_LDA:LDAEvaluationWordNet" compatibility="1.1.001" expanded="true" height="82" name="LDAEvaluationWordNet" width="90" x="380" y="34">
        <parameter key="iterations" value="2000"/>
        <parameter key="word net source files" value="/home/poelitz/Downloads/WordNet-2.1/dict"/>
        <parameter key="method" value="WuPalmer"/>
      <connect from_op="Loop Files (2)" from_port="output 1" to_op="Union Append" to_port="in 1"/>
      <connect from_op="Union Append" from_port="out 1" to_op="LDAEvaluationWordNet" to_port="example set input"/>
      <connect from_op="Open WordNet Dictionary" from_port="dictionary" to_op="LDAEvaluationWordNet" to_port="example set words"/>
      <connect from_op="LDAEvaluationWordNet" from_port="output neg log likelihoods" to_port="result 1"/>
    </process>
</process>
Best Answer
  • Ka13n
    Dear Scott
    Thanks for your kindly reply, I'll shoot him an email for the solution! :smile:
