Is it possible to create a Duplicate Operator like a Link?
esimone
New Altair Community Member
I've got a maybe strange question.
In my processes, sometimes I would like to have something like a "duplicate operator", but not just a copy.
I would like, for example, to create two operators of type Performance: Perfomance_A and Performance_B.
When I edit the params of Performance_A, then also those of Performance_B change (like a clone, but not indipendent), and viceversa. Is it possible?
Best Answer
At the end, I found "Clone Paramters" that is what I was looking for. Thank you.
3
Kind of. You could use so-called macros for this. Use the operator Set Macro (or the process context) to define those „global“ value and then use them in the parameters of the operator clones with this format: %{macro_name}.
Check out the videos on the RapidMiner Academy to learn more about macros - they are really powerful tools!
Cheers,
Ingo2 -
3 -
That works tooStill learning about macros is always a good idea since they can be used to solve A LOT of problems ;-)1
