<?xml version="1.0" encoding="UTF-8"?><process version="9.6.000-SNAPSHOT"><br> <context><br> <input/><br> <output/><br> <macros/><br> </context><br> <operator activated="true" class="process" compatibility="9.6.000-SNAPSHOT" expanded="true" name="Process"><br> <parameter key="logverbosity" value="init"/><br> <parameter key="random_seed" value="2001"/><br> <parameter key="send_mail" value="never"/><br> <parameter key="notification_email" value=""/><br> <parameter key="process_duration_for_mail" value="30"/><br> <parameter key="encoding" value="UTF-8"/><br> <process expanded="true"><br> <operator activated="true" class="retrieve" compatibility="9.6.000-SNAPSHOT" expanded="true" height="68" name="Retrieve Sonar" width="90" x="45" y="34"><br> <parameter key="repository_entry" value="//Samples/data/Sonar"/><br> </operator><br> <operator activated="true" class="support_vector_machine" compatibility="9.6.000-SNAPSHOT" expanded="true" height="124" name="SVM" width="90" x="179" y="34"><br> <parameter key="kernel_type" value="dot"/><br> <parameter key="kernel_gamma" value="1.0"/><br> <parameter key="kernel_sigma1" value="1.0"/><br> <parameter key="kernel_sigma2" value="0.0"/><br> <parameter key="kernel_sigma3" value="2.0"/><br> <parameter key="kernel_shift" value="1.0"/><br> <parameter key="kernel_degree" value="2.0"/><br> <parameter key="kernel_a" value="1.0"/><br> <parameter key="kernel_b" value="0.0"/><br> <parameter key="kernel_cache" value="200"/><br> <parameter key="C" value="0.0"/><br> <parameter key="convergence_epsilon" value="0.001"/><br> <parameter key="max_iterations" value="100000"/><br> <parameter key="scale" value="true"/><br> <parameter key="calculate_weights" value="true"/><br> <parameter key="return_optimization_performance" value="true"/><br> <parameter key="L_pos" value="1.0"/><br> <parameter key="L_neg" value="1.0"/><br> <parameter key="epsilon" value="0.0"/><br> <parameter key="epsilon_plus" value="0.0"/><br> <parameter key="epsilon_minus" value="0.0"/><br> <parameter key="balance_cost" value="false"/><br> <parameter key="quadratic_loss_pos" value="false"/><br> <parameter key="quadratic_loss_neg" value="false"/><br> <parameter key="estimate_performance" value="false"/><br> </operator><br> <operator activated="true" class="create_formula" compatibility="9.6.000-SNAPSHOT" expanded="true" height="82" name="Create Formula" width="90" x="313" y="34"/><br> <connect from_op="Retrieve Sonar" from_port="output" to_op="SVM" to_port="training set"/><br> <connect from_op="SVM" from_port="model" to_op="Create Formula" to_port="model"/><br> <connect from_op="Create Formula" from_port="formula" to_port="result 1"/><br> <portSpacing port="source_input 1" spacing="0"/><br> <portSpacing port="sink_result 1" spacing="0"/><br> <portSpacing port="sink_result 2" spacing="0"/><br> </process><br> </operator><br></process><br><br>
