<process version="9.5.001"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="9.5.001" expanded="true" name="Process"> <parameter key="logverbosity" value="init"/> <parameter key="random_seed" value="2001"/> <parameter key="send_mail" value="never"/> <parameter key="notification_email" value=""/> <parameter key="process_duration_for_mail" value="30"/> <parameter key="encoding" value="SYSTEM"/> <process expanded="true"> <operator activated="true" class="retrieve" compatibility="9.5.001" expanded="true" height="68" name="Retrieve Prices of Gas Station" width="90" x="112" y="34"> <parameter key="repository_entry" value="//Samples/Time Series/data sets/Prices of Gas Station"/> </operator> <operator activated="true" class="time_series:sliding_window_validation" compatibility="9.5.000" expanded="true" height="145" name="Sliding Window Validation" width="90" x="313" y="34"> <parameter key="has_indices" value="true"/> <parameter key="indices_attribute" value="date"/> <parameter key="training_window_size" value="7000"/> <parameter key="no_overlapping_windows" value="true"/> <parameter key="step_size" value="500"/> <parameter key="test_window_size" value="1000"/> <parameter key="enable_parallel_execution" value="true"/> <process expanded="true"> <operator activated="true" class="concurrency:optimize_parameters_grid" compatibility="9.5.001" expanded="true" height="145" name="Optimize Parameters (Grid)" width="90" x="179" y="34"> <list key="parameters"> <parameter key="Windowing.window_size" value="[12;48;3;linear]"/> <parameter key="Linear Regression.use_bias" value="true,false"/> </list> <parameter key="error_handling" value="fail on error"/> <parameter key="log_performance" value="true"/> <parameter key="log_all_criteria" value="false"/> <parameter key="synchronize" value="false"/> <parameter key="enable_parallel_execution" value="true"/> <process expanded="true"> <operator activated="true" class="time_series:windowing" compatibility="9.5.000" expanded="true" height="82" name="Windowing" width="90" x="112" y="34"> <parameter key="attribute_filter_type" value="all"/> <parameter key="attribute" value=""/> <parameter key="attributes" value=""/> <parameter key="use_except_expression" value="false"/> <parameter key="value_type" value="nominal"/> <parameter key="use_value_type_exception" value="false"/> <parameter key="except_value_type" value="time"/> <parameter key="block_type" value="single_value"/> <parameter key="use_block_type_exception" value="false"/> <parameter key="except_block_type" value="value_matrix_row_start"/> <parameter key="invert_selection" value="false"/> <parameter key="include_special_attributes" value="false"/> <parameter key="has_indices" value="true"/> <parameter key="indices_attribute" value="date"/> <parameter key="window_size" value="48"/> <parameter key="no_overlapping_windows" value="false"/> <parameter key="step_size" value="1"/> <parameter key="create_horizon_(labels)" value="true"/> <parameter key="horizon_attribute" value="gas price / euro (times 1000)"/> <parameter key="horizon_size" value="1"/> <parameter key="horizon_offset" value="23"/> </operator> <operator activated="true" class="operator_toolbox:get_parameters" compatibility="2.2.000" expanded="true" height="103" name="Get Parameters" width="90" x="313" y="187"> <parameter key="operator_name" value="Windowing"/> </operator> <operator activated="true" class="time_series:sliding_window_validation" compatibility="9.5.000" expanded="true" height="145" name="Sliding Window Validation (2)" width="90" x="514" y="34"> <parameter key="has_indices" value="false"/> <parameter key="indices_attribute" value=""/> <parameter key="training_window_size" value="4000"/> <parameter key="no_overlapping_windows" value="true"/> <parameter key="step_size" value="500"/> <parameter key="test_window_size" value="500"/> <parameter key="enable_parallel_execution" value="true"/> <process expanded="true"> <operator activated="true" class="linear_regression" compatibility="9.5.001" expanded="true" height="103" name="Linear Regression" width="90" x="179" y="34"> <parameter key="feature_selection" value="M5 prime"/> <parameter key="alpha" value="0.05"/> <parameter key="max_iterations" value="10"/> <parameter key="forward_alpha" value="0.05"/> <parameter key="backward_alpha" value="0.05"/> <parameter key="eliminate_colinear_features" value="true"/> <parameter key="min_tolerance" value="0.05"/> <parameter key="use_bias" value="true"/> <parameter key="ridge" value="1.0E-8"/> </operator> <connect from_port="training set" to_op="Linear Regression" to_port="training set"/> <connect from_op="Linear Regression" from_port="model" to_port="model"/> <portSpacing port="source_training set" spacing="0"/> <portSpacing port="sink_model" spacing="0"/> <portSpacing port="sink_through 1" spacing="0"/> </process> <process expanded="true"> <operator activated="true" class="apply_model" compatibility="9.5.001" expanded="true" height="82" name="Apply Model" width="90" x="112" y="34"> <list key="application_parameters"/> <parameter key="create_view" value="false"/> </operator> <operator activated="true" class="performance_regression" compatibility="9.5.001" expanded="true" height="82" name="Performance" width="90" x="246" y="34"> <parameter key="main_criterion" value="first"/> <parameter key="root_mean_squared_error" value="true"/> <parameter key="absolute_error" value="false"/> <parameter key="relative_error" value="false"/> <parameter key="relative_error_lenient" value="false"/> <parameter key="relative_error_strict" value="false"/> <parameter key="normalized_absolute_error" value="false"/> <parameter key="root_relative_squared_error" value="false"/> <parameter key="squared_error" value="false"/> <parameter key="correlation" value="false"/> <parameter key="squared_correlation" value="false"/> <parameter key="prediction_average" value="false"/> <parameter key="spearman_rho" value="false"/> <parameter key="kendall_tau" value="false"/> <parameter key="skip_undefined_labels" value="true"/> <parameter key="use_example_weights" value="true"/> </operator> <connect from_port="test set" to_op="Apply Model" to_port="unlabelled data"/> <connect from_port="model" to_op="Apply Model" to_port="model"/> <connect from_op="Apply Model" from_port="labelled data" to_op="Performance" to_port="labelled data"/> <connect from_op="Performance" from_port="performance" to_port="performance 1"/> <portSpacing port="source_test set" spacing="0"/> <portSpacing port="source_model" spacing="0"/> <portSpacing port="source_through 1" spacing="0"/> <portSpacing port="sink_test set results" spacing="0"/> <portSpacing port="sink_performance 1" spacing="0"/> <portSpacing port="sink_performance 2" spacing="0"/> </process> </operator> <connect from_port="input 1" to_op="Windowing" to_port="example set"/> <connect from_op="Windowing" from_port="windowed example set" to_op="Get Parameters" to_port="through 1"/> <connect from_op="Get Parameters" from_port="parameters" to_port="output 1"/> <connect from_op="Get Parameters" from_port="through 1" to_op="Sliding Window Validation (2)" to_port="example set"/> <connect from_op="Sliding Window Validation (2)" from_port="model" to_port="model"/> <connect from_op="Sliding Window Validation (2)" from_port="performance 1" to_port="performance"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="source_input 2" spacing="0"/> <portSpacing port="sink_performance" spacing="0"/> <portSpacing port="sink_model" spacing="0"/> <portSpacing port="sink_output 1" spacing="0"/> <portSpacing port="sink_output 2" spacing="0"/> </process> </operator> <connect from_port="training set" to_op="Optimize Parameters (Grid)" to_port="input 1"/> <connect from_op="Optimize Parameters (Grid)" from_port="model" to_port="model"/> <connect from_op="Optimize Parameters (Grid)" from_port="parameter set" to_port="through 1"/> <portSpacing port="source_training set" spacing="0"/> <portSpacing port="sink_model" spacing="0"/> <portSpacing port="sink_through 1" spacing="0"/> <portSpacing port="sink_through 2" spacing="0"/> </process> <process expanded="true"> <operator activated="true" class="set_parameters" compatibility="9.5.001" expanded="true" height="124" name="Set Parameters" width="90" x="112" y="85"> <list key="name_map"> <parameter key="Windowing" value="Windowing Testing"/> </list> </operator> <operator activated="true" class="time_series:windowing" compatibility="9.5.000" expanded="true" height="82" name="Windowing Testing" width="90" x="246" y="34"> <parameter key="attribute_filter_type" value="all"/> <parameter key="attribute" value=""/> <parameter key="attributes" value=""/> <parameter key="use_except_expression" value="false"/> <parameter key="value_type" value="nominal"/> <parameter key="use_value_type_exception" value="false"/> <parameter key="except_value_type" value="time"/> <parameter key="block_type" value="single_value"/> <parameter key="use_block_type_exception" value="false"/> <parameter key="except_block_type" value="value_matrix_row_start"/> <parameter key="invert_selection" value="false"/> <parameter key="include_special_attributes" value="false"/> <parameter key="has_indices" value="true"/> <parameter key="indices_attribute" value="date"/> <parameter key="window_size" value="48"/> <parameter key="no_overlapping_windows" value="false"/> <parameter key="step_size" value="1"/> <parameter key="create_horizon_(labels)" value="true"/> <parameter key="horizon_attribute" value="gas price / euro (times 1000)"/> <parameter key="horizon_size" value="1"/> <parameter key="horizon_offset" value="23"/> </operator> <operator activated="true" class="apply_model" compatibility="9.5.001" expanded="true" height="82" name="Apply Model (2)" width="90" x="380" y="136"> <list key="application_parameters"/> <parameter key="create_view" value="false"/> </operator> <operator activated="true" class="performance_regression" compatibility="9.5.001" expanded="true" height="82" name="Performance (2)" width="90" x="581" y="34"> <parameter key="main_criterion" value="first"/> <parameter key="root_mean_squared_error" value="true"/> <parameter key="absolute_error" value="false"/> <parameter key="relative_error" value="false"/> <parameter key="relative_error_lenient" value="false"/> <parameter key="relative_error_strict" value="false"/> <parameter key="normalized_absolute_error" value="false"/> <parameter key="root_relative_squared_error" value="false"/> <parameter key="squared_error" value="false"/> <parameter key="correlation" value="false"/> <parameter key="squared_correlation" value="false"/> <parameter key="prediction_average" value="false"/> <parameter key="spearman_rho" value="false"/> <parameter key="kendall_tau" value="false"/> <parameter key="skip_undefined_labels" value="true"/> <parameter key="use_example_weights" value="true"/> </operator> <connect from_port="test set" to_op="Set Parameters" to_port="through 1"/> <connect from_port="model" to_op="Set Parameters" to_port="through 2"/> <connect from_port="through 1" to_op="Set Parameters" to_port="parameter set"/> <connect from_op="Set Parameters" from_port="through 1" to_op="Windowing Testing" to_port="example set"/> <connect from_op="Set Parameters" from_port="through 2" to_op="Apply Model (2)" to_port="model"/> <connect from_op="Windowing Testing" from_port="windowed example set" to_op="Apply Model (2)" to_port="unlabelled data"/> <connect from_op="Apply Model (2)" from_port="labelled data" to_op="Performance (2)" to_port="labelled data"/> <connect from_op="Performance (2)" from_port="performance" to_port="performance 1"/> <portSpacing port="source_test set" spacing="0"/> <portSpacing port="source_model" spacing="0"/> <portSpacing port="source_through 1" spacing="0"/> <portSpacing port="source_through 2" spacing="0"/> <portSpacing port="sink_test set results" spacing="0"/> <portSpacing port="sink_performance 1" spacing="0"/> <portSpacing port="sink_performance 2" spacing="0"/> </process> </operator> <connect from_op="Retrieve Prices of Gas Station" from_port="output" to_op="Sliding Window Validation" to_port="example set"/> <connect from_op="Sliding Window Validation" from_port="model" to_port="result 2"/> <connect from_op="Sliding Window Validation" from_port="performance 1" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> <portSpacing port="sink_result 3" spacing="0"/> </process> </operator> </process>
