Evaluation of Classification models
Muhammed_Fatih_
Hello together,
is there a possibility within RapidMiner to parallelly train and test selected classification models and subsequently return the best performance result of the respective classification model? The goal of my research is to evaluate the behaviour of classification models with regard to the determination of the best performance.
Thank you for your answers!
Best regards,
Fatih
Classification
Performance
Compare Models
sgenzer
Hello
@Muhammed_Fatih_
absolutely. It's called "Auto Model" and it's at the top of your screen.
sgenzer
Hello
@Muhammed_Fatih_
Muhammed_Fatih_
Hi
@sgenzer
thank you for your answer which was very helpful
Is there also the possibility to execute ROC Comparison with Cross-Validation?
lionelderkrikor
Hi
@Muhammed_Fatih_
1. Inside AutoModel, by default, the model(s) is (are) not validated by a cross-validation, but by a multi - hold-out-set validation.
See the documentation on the "results" screen :
You can also inspect the generated process(es) after executing AutoModel to inspect them and understand exactly how is (are)
calculated the performance of the model(s).
2. If you want to obtain the comparaison of ROC curves with a cross-validation, you can use the
Compare ROCs
operator.
Simply put the models you want to benchmark inside this operator.
Hope this helps,
Lionel
