Our team created a visual process within Automator where 2 different files are used. Within the File Input properties, I've specified a filename with a wildcard (e.g. CRJ Weekly Test\AUD200G1#72M*) due to different dates added each day. The process is setup with an input monitored trigger for any file added to the "CRJ Weekly Test" folder.
Even when adding a file that is named outside of "AUD200G1#72M" the process is still triggered. It does complete with warning that no file was processed, but I wanted to know if there was a way to avoid the process from triggering when filenames do not match. Please let me know if you need any additional information.
Thanks!
Tony Ruffy
Sr Analyst
