<?xml version="1.0" encoding="UTF-8"?><process version="9.5.000"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="9.4.000" expanded="true" name="Process" origin="GENERATED_TUTORIAL"> <parameter key="logverbosity" value="init"/> <parameter key="random_seed" value="2001"/> <parameter key="send_mail" value="never"/> <parameter key="notification_email" value=""/> <parameter key="process_duration_for_mail" value="30"/> <parameter key="encoding" value="SYSTEM"/> <process expanded="true"> <operator activated="true" class="retrieve" compatibility="9.5.000" expanded="true" height="68" name="Retrieve Golf" origin="GENERATED_TUTORIAL" width="90" x="45" y="34"> <parameter key="repository_entry" value="//Samples/data/Golf"/> </operator> <operator activated="true" class="concurrency:cross_validation" compatibility="8.2.000" expanded="true" height="145" name="Validation" origin="GENERATED_TUTORIAL" width="90" x="447" y="34"> <parameter key="split_on_batch_attribute" value="false"/> <parameter key="leave_one_out" value="false"/> <parameter key="number_of_folds" value="10"/> <parameter key="sampling_type" value="stratified sampling"/> <parameter key="use_local_random_seed" value="false"/> <parameter key="local_random_seed" value="1992"/> <parameter key="enable_parallel_execution" value="true"/> <process expanded="true"> <operator activated="true" class="concurrency:parallel_decision_tree" compatibility="9.4.000" expanded="true" height="103" name="Decision Tree" origin="GENERATED_TUTORIAL" width="90" x="179" y="34"> <parameter key="criterion" value="gain_ratio"/> <parameter key="maximal_depth" value="10"/> <parameter key="apply_pruning" value="true"/> <parameter key="confidence" value="0.1"/> <parameter key="apply_prepruning" value="true"/> <parameter key="minimal_gain" value="0.01"/> <parameter key="minimal_leaf_size" value="2"/> <parameter key="minimal_size_for_split" value="4"/> <parameter key="number_of_prepruning_alternatives" value="3"/> </operator> <connect from_port="training set" to_op="Decision Tree" to_port="training set"/> <connect from_op="Decision Tree" from_port="model" to_port="model"/> <portSpacing port="source_training set" spacing="0"/> <portSpacing port="sink_model" spacing="0"/> <portSpacing port="sink_through 1" spacing="0"/> <description align="left" color="green" colored="true" height="80" resized="true" width="248" x="37" y="137">In the training phase, a model is built on the current training data set. (90 % of data by default, 10 times)</description> </process> <process expanded="true"> <operator activated="true" class="apply_model" compatibility="9.5.000" expanded="true" height="82" name="Apply Model" origin="GENERATED_TUTORIAL" width="90" x="45" y="34"> <list key="application_parameters"/> <parameter key="create_view" value="false"/> </operator> <operator activated="true" class="performance_binominal_classification" compatibility="9.5.000" expanded="true" height="82" name="Performance (2)" origin="GENERATED_TUTORIAL" width="90" x="313" y="34"> <parameter key="manually_set_positive_class" value="false"/> <parameter key="main_criterion" value="first"/> <parameter key="accuracy" value="true"/> <parameter key="classification_error" value="false"/> <parameter key="kappa" value="false"/> <parameter key="AUC (optimistic)" value="false"/> <parameter key="AUC" value="true"/> <parameter key="AUC (pessimistic)" value="true"/> <parameter key="precision" value="false"/> <parameter key="recall" value="false"/> <parameter key="lift" value="false"/> <parameter key="fallout" value="false"/> <parameter key="f_measure" value="false"/> <parameter key="false_positive" value="false"/> <parameter key="false_negative" value="false"/> <parameter key="true_positive" value="false"/> <parameter key="true_negative" value="false"/> <parameter key="sensitivity" value="false"/> <parameter key="specificity" value="false"/> <parameter key="youden" value="false"/> <parameter key="positive_predictive_value" value="false"/> <parameter key="negative_predictive_value" value="false"/> <parameter key="psep" value="false"/> <parameter key="skip_undefined_labels" value="true"/> <parameter key="use_example_weights" value="true"/> </operator> <connect from_port="model" to_op="Apply Model" to_port="model"/> <connect from_port="test set" to_op="Apply Model" to_port="unlabelled data"/> <connect from_op="Apply Model" from_port="labelled data" to_op="Performance (2)" to_port="labelled data"/> <connect from_op="Performance (2)" from_port="performance" to_port="performance 1"/> <connect from_op="Performance (2)" from_port="example set" to_port="test set results"/> <portSpacing port="source_model" spacing="0"/> <portSpacing port="source_test set" spacing="0"/> <portSpacing port="source_through 1" spacing="0"/> <portSpacing port="sink_test set results" spacing="0"/> <portSpacing port="sink_performance 1" spacing="0"/> <portSpacing port="sink_performance 2" spacing="0"/> <description align="left" color="blue" colored="true" height="103" resized="true" width="315" x="38" y="137">The model created in the Training step is applied to the current test set (10 %).<br/>The performance is evaluated and sent to the operator results.</description> </process> <description align="center" color="transparent" colored="false" width="126">A cross-validation evaluating a decision tree model.</description> </operator> <operator activated="true" breakpoints="after" class="converters:confusionmatrix_2_example_set" compatibility="0.6.000" expanded="true" height="82" name="Confusion Matrix to ExampleSet" origin="GENERATED_TUTORIAL" width="90" x="648" y="136"/> <operator activated="true" class="extract_macro" compatibility="9.5.000" expanded="true" height="68" name="Extract Macro TP" width="90" x="782" y="136"> <parameter key="macro" value="TP"/> <parameter key="macro_type" value="data_value"/> <parameter key="statistics" value="average"/> <parameter key="attribute_name" value="true yes"/> <parameter key="example_index" value="2"/> <list key="additional_macros"/> </operator> <operator activated="true" class="extract_macro" compatibility="9.5.000" expanded="true" height="68" name="Extract Macro TN" width="90" x="916" y="136"> <parameter key="macro" value="TN"/> <parameter key="macro_type" value="data_value"/> <parameter key="statistics" value="average"/> <parameter key="attribute_name" value="true no"/> <parameter key="example_index" value="1"/> <list key="additional_macros"/> </operator> <operator activated="true" class="extract_macro" compatibility="9.5.000" expanded="true" height="68" name="Extract Macro FN" width="90" x="1050" y="136"> <parameter key="macro" value="FN"/> <parameter key="macro_type" value="data_value"/> <parameter key="statistics" value="average"/> <parameter key="attribute_name" value="true yes"/> <parameter key="example_index" value="1"/> <list key="additional_macros"/> </operator> <operator activated="true" breakpoints="after" class="extract_macro" compatibility="9.5.000" expanded="true" height="68" name="Extract Macro FP" width="90" x="1184" y="136"> <parameter key="macro" value="FP"/> <parameter key="macro_type" value="data_value"/> <parameter key="statistics" value="average"/> <parameter key="attribute_name" value="true no"/> <parameter key="example_index" value="2"/> <list key="additional_macros"/> </operator> <operator activated="true" class="generate_macro" compatibility="9.5.000" expanded="true" height="82" name="Generate Macro" width="90" x="1318" y="136"> <list key="function_descriptions"> <parameter key="MCC" value="(eval(%{TP})*eval(%{TN})-eval(%{FP})*eval(%{FN}))/(sqrt((eval(%{TP})+eval(%{FP}))*(eval(%{TP})+eval(%{FN}))*(eval(%{TN})+eval(%{FP}))*(eval(%{TN})+eval(%{FN}))))"/> </list> </operator> <operator activated="true" class="utility:create_exampleset" compatibility="9.5.000" expanded="true" height="68" name="Create ExampleSet" width="90" x="1117" y="238"> <parameter key="generator_type" value="comma separated text"/> <parameter key="number_of_examples" value="100"/> <parameter key="use_stepsize" value="false"/> <list key="function_descriptions"/> <parameter key="add_id_attribute" value="false"/> <list key="numeric_series_configuration"/> <list key="date_series_configuration"/> <list key="date_series_configuration (interval)"/> <parameter key="date_format" value="yyyy-MM-dd HH:mm:ss"/> <parameter key="time_zone" value="SYSTEM"/> <parameter key="input_csv_text" value="MCC %{MCC}"/> <parameter key="column_separator" value=","/> <parameter key="parse_all_as_nominal" value="false"/> <parameter key="decimal_point_character" value="."/> <parameter key="trim_attribute_names" value="true"/> </operator> <connect from_op="Retrieve Golf" from_port="output" to_op="Validation" to_port="example set"/> <connect from_op="Validation" from_port="performance 1" to_op="Confusion Matrix to ExampleSet" to_port="per"/> <connect from_op="Confusion Matrix to ExampleSet" from_port="exa" to_op="Extract Macro TP" to_port="example set"/> <connect from_op="Confusion Matrix to ExampleSet" from_port="ori" to_port="result 2"/> <connect from_op="Extract Macro TP" from_port="example set" to_op="Extract Macro TN" to_port="example set"/> <connect from_op="Extract Macro TN" from_port="example set" to_op="Extract Macro FN" to_port="example set"/> <connect from_op="Extract Macro FN" from_port="example set" to_op="Extract Macro FP" to_port="example set"/> <connect from_op="Extract Macro FP" from_port="example set" to_op="Generate Macro" to_port="through 1"/> <connect from_op="Generate Macro" from_port="through 1" to_port="result 1"/> <connect from_op="Create ExampleSet" from_port="output" to_port="result 3"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> <portSpacing port="sink_result 3" spacing="0"/> <portSpacing port="sink_result 4" spacing="0"/> </process> </operator> </process>
