Problem, regarding filepath, when reading a file that is stored on the RM Server.
User: "Christos_Karapapas"
New Altair Community Member
Updated by Jocelyn
I have a RM Server running on a VM (Ubuntu) on top of my Win10 machine.
I have a process to read a .csv file and write its contents on a MySQL database on a MySQL Server which also runs on the same VM.
The problem is that the read file operator does not seem to be able to find the file.
Scenario1.
When I try as location-name in the read csv operator `../data/myFile.csv`
And run the process on Server I am getting `Failed to execute initialization process: Error executing process /apps/myApp/process/task_read_csv_to_db: The file 'java.io.FileNotFoundException: /root/../data/myFile.csv (No such file or directory)' does not exist.`
Scenario2.
When I try as location-name in the read csv operator `/apps/myApp/data/myFile.csv`
And run the process on Server I am getting `Failed to execute initialization process: Error executing process /apps/myApp/process/task_read_csv_to_db: The file 'java.io.FileNotFoundException: /apps/myApp/data/myFile.csv (No such file or directory)' does not exist.`
What is the right filepath that I should give to the Read CSV operator?
1 - 1 of 11
    User: "David_A"
    Accepted Answer
    the repository is stored in /rapidminer-server-home/data/repository
    But you can't access the files stored there directly. As a layer of security the file names and locations are scrambled and encrypted (otherwise for example the user access rights would be pointless).
    I would recommend to store the *.csv file in a more generic folder, for example /tmp/ or another folder where each related user has access rights.
    I hope this helps you.
    Best,
    David
