How to include an id# in auto model predict result without it contributing to input.
dons
I've tried making it an id or label. It doesn't appear in the result column unless I make it an input, in which case it contributes to the input which I don' want.
Auto Model
lionelderkrikor
Hi Don,
To be more precise :
- Click on the
Define Target (Set Role)
operator and then click on
Edit List :
Then :
Then you can run the process...
Lionel
lionelderkrikor
Hi
@dons
I'm not sure to understand.
But if we take example on the Iris dataset :
1/ Check the Id column in order the id is taken into account
2/ Execute
Automodel
3/ Open a process (when the execution is completed).
4/ Go to
Load and Process Data
5/ GO to
Preprocessing
Define Target ?
6/ In the
operator set your id column as
id
in the parameters.
This way, your id column/attribute will appear as "id" in the results tables.
Hope this helps,
Lionel
dons
Thank you Lionel. After Predict runs, I click on General, Data, and Open Process. Then as you indicated, Preprocessing, and Define Target. Then Set Role example set output.
I highlight the out circle on the far right and click on the id#. The Role box is blank, and I don't see a way to set it to id. Don
lionelderkrikor
Hi Don,
- Click on the
Edit List :
Then :
Lionel
dons
Thank you Lionel. Please check this, After Predict runs, I clicked on General, Data, and Open Process. Then as you showed, Load and Process Data, Preprocessing, Define Target. In the upper right Actions is picked. On the far right, I click on Set Role examples set output
dons
Thank you Lionel for your detailed instructions.
Don
lionelderkrikor
You're welcome, Don.
Lionel
