Has something changed with the execute programs operator?
<?xml version="1.0" encoding="UTF-8"?><process version="9.4.001">
<context>
<input/>
<output/>
<macros/>
</context>
<operator activated="true" class="process" compatibility="9.4.001" expanded="true" name="Process">
<process expanded="true">
<operator activated="true" class="text:create_document" compatibility="8.2.000" expanded="true" height="68" name="generate query" width="90" x="45" y="85">
<parameter key="text" value="aws athena start-query-execution --query-string "select * from table where col0 like 'number';" --result-configuration "OutputLocation=s3://" "/>
<parameter key="add label" value="false"/>
<parameter key="label_type" value="nominal"/>
<operator activated="true" class="text:write_document" compatibility="8.2.000" expanded="true" height="82" name="overwrite query" width="90" x="179" y="85">
<parameter key="file" value="/Users/robinmeisel/Dropbox/psyscore/master.sh"/>
<parameter key="overwrite" value="true"/>
<operator activated="true" class="productivity:execute_program" compatibility="9.4.001" expanded="true" height="124" name="Execute Program" width="90" x="313" y="85">
<parameter key="command" value="chmod +x master.sh"/>
<parameter key="log_stdout" value="true"/>
<parameter key="log_stderr" value="false"/>
<parameter key="working_directory" value="/Users/execute"/>
<list key="env_variables"/>
<operator activated="true" class="productivity:execute_program" compatibility="9.4.001" expanded="true" height="124" name="Execute Program (2)" width="90" x="447" y="85">
<parameter key="command" value="./master.sh"/>
<parameter key="log_stderr" value="true"/>
<connect from_op="generate query" from_port="output" to_op="overwrite query" to_port="document"/>
<connect from_op="overwrite query" from_port="document" to_op="Execute Program" to_port="through 1"/>
<connect from_op="Execute Program" from_port="out" to_op="Execute Program (2)" to_port="through 1"/>
</process>
</process>I am now getting this error where the process used to work perfectly. Any ideas?
