1. I'm a beginner and recently started to work on Acusolve. I wanted to to get the flow trajectory (Streamline) of water coming out of a pipe into atmosphere (Medium- Air). So may I know whether this can be achieved using Acusolve, if yes, may I know the steps.
2. I have got the result for velocity and pressure at the outlet of pipe (flow through pipe problem), can the same values be used as inlet condition for the above problem or can both problems be combined?
Thank you.
