Boxplot in Visualizations menu is not showing outliers
Hi all,
Apparently when I check the results of a dataset I don't see the outliers (and mean) in the boxplot-plot option. The wiskers go to min and max value (First plot is python boxplot, second is the RM boxplot).
So this is actually not a boxplot
Currently I have to install the Turkey-extension to have outlier detection for each attribute..
Is it a setting to show outliers?
What can I do about it?
I have installed RM Studio 9.3 and have an Educational License.
Thank you!
Thank you!
1 - 3 of
31
1 - 1 of
11
Box and whisker plots quartiles, and the band inside the box is always the second quartile (the median). But the ends of the whiskers can represent several possible alternative values, among them:
Any data not included between the whiskers should be plotted as an outlier with a dot, small circle, or star, but occasionally this is not done.
