A decision tree is a tree like collection of nodes intended to create a decision on values affiliation to a class or an estimate of a numerical target value. Each node represents a splitting rule for one specific Attribute. For classification this rule separates values belonging to different classes, for regression it separates them in order to reduce the error in an optimal way for the selected parameter criterion.
The building of new nodes is repeated until the stopping criteria are met. A prediction for the class label Attribute is determined depending on the majority of Examples which reached this leaf during generation, while an estimation for a numerical value is obtained by averaging the values in a leaf.
This Operator can process ExampleSets containing both nominal and numerical Attributes. The label Attribute must be nominal for classification and numerical for regression.
After generation, the decision tree model can be applied to new Examples using the Apply Model Operator. Each Example follows the branches of the tree in accordance to the splitting rule until a leaf is reached.
To configure the decision tree, please read the documentation on parameters as explained below.
look at this link please:
https://docs.rapidminer.com/latest/studio/operators/modeling/predictive/trees/parallel_decision_tree.html
regards
mbs
