Python Code not running on server
Niharika
I have created this python process in my studio when I am exporting this process as a web service and calling it from Postman I am getting following error.
I have installed the extension on server and updated the job-agent
Server
Python
Pavithra_Rao
@Niharika
The easiest way to test the issue is to run this Python process on RapidMiner Server, (not on Studio installed on VM, where the Server is hosted)
https://docs.rapidminer.com/latest/server/use/run-a-process/run-from-studio.html
This will help look into the error within the Server logs and then would be easier to export this process as REST API end-points
Pavithra
varunm1
Hello
@Niharika
Did you test the installed python package to see if Rapidminer is detecting "pandas" module?
Just to double-check, did you create a system settings for python in the rapidminer server. You need to add a property rapidminer.python_scripting.path in property and the path to your python (installed) in value column.
Niharika
Hi How do I check for the python package.My server has been hosted on a VM. On that VM I am able to run a code which runs 'pandas' package..
In the Server System settings I have added following:
rapidminer.python_scripting.hidden.initialized=true
rapidminer.python_scripting.package_manager=
conda (anaconda)
rapidminer.python_scripting.search_paths=C:\Anaconda3\python.exe
varunm1
I am tagging
@Pavithra_Rao
and
@David_A
who might help you.
Niharika
Okay thanks
Pavithra_Rao
@Niharika
Pavithra
