Im new in Rapidminer, can someone help me with this Kaggle challenge ? only got 69% right
Xandesaraiva_
New Altair Community Member
<context>
<input>
<location>//Local Repository/data/1º DESAFIO</location>
</input>
<output/>
<macros/>
</context>
<operator activated="true" class="process" compatibility="9.3.001" expanded="true" name="Process">
<process expanded="true">
<operator activated="true" class="retrieve" compatibility="9.3.001" expanded="true" height="68" name="Retrieve 1º DESAFIO" width="90" x="45" y="34">
<parameter key="repository_entry" value="//Local Repository/data/1º DESAFIO"/>
<operator activated="true" class="naive_bayes" compatibility="9.3.001" expanded="true" height="82" name="Naive Bayes" width="90" x="179" y="34">
<parameter key="laplace_correction" value="true"/>
<operator activated="true" class="apply_model" compatibility="9.3.001" expanded="true" height="82" name="Apply Model" width="90" x="313" y="34">
<parameter key="create_view" value="false"/>
<operator activated="true" class="performance" compatibility="9.3.001" expanded="true" height="82" name="Performance" width="90" x="447" y="34">
<parameter key="use_example_weights" value="true"/>
<connect from_op="Retrieve 1º DESAFIO" from_port="output" to_op="Naive Bayes" to_port="training set"/>
<connect from_op="Naive Bayes" from_port="model" to_op="Apply Model" to_port="model"/>
<connect from_op="Naive Bayes" from_port="exampleSet" to_op="Apply Model" to_port="unlabelled data"/>
<connect from_op="Performance" from_port="performance" to_port="result 2"/>
<connect from_op="Performance" from_port="example set" to_port="result 1"/>
</process>
</process>
the goal is to find out (starting by the number 892) if the person survived or not. databases (train)0
hi @Xandesaraiva_ great to have you here! Maybe can you please give us a bit more info (Which Kaggle challenge? There are thousands). And the XML you posted is cut off. Could you please try editing your message or posting a new reply with a clean copy?
Scott2 -
Hello @Xandesaraiva_
From your .rmp file, I can say that you are training and testing on the same dataset. If you are interested in learning good validation methods or how the Rapidminer process work, you can go to the rapidminer academy that consists of tutorial videos (easy to understand).
https://academy.rapidminer.com/
If you need more information or any help with the processes we are happy to help as well.
Thanks1
