grams word cloud representation
jmphillips
Hello: My rapidminer model represent in R wordclouds, but represent 1 gram, 2 grams, etc.
The question is: can I, only represent in a wordcloud 2 grams, how to filter, exclude 1 grams.
Text Mining + NLP
jmphillips
<?xml version="1.0" encoding="UTF-8"?><process version="9.3.001">
<context>
<input/>
<output/>
<macros/>
</context>
<operator activated="true" class="process" compatibility="6.0.002" expanded="true" name="Process">
<process expanded="true">
<operator activated="true" class="loop_files" compatibility="9.3.001" expanded="true" height="103" name="Loop Files" width="90" x="112" y="34">
<parameter key="directory" value="C:\CENDOC\input\txt"/>
<parameter key="filtered_string" value="file name (last part of the path)"/>
<parameter key="file_name_macro" value="file_name_TEST"/>
<parameter key="file_path_macro" value="file_path"/>
<parameter key="parent_path_macro" value="parent_path"/>
<parameter key="recursive" value="false"/>
<parameter key="iterate_over_files" value="true"/>
<parameter key="iterate_over_subdirs" value="false"/>
<operator activated="true" class="text:read_document" compatibility="8.2.000" expanded="true" height="68" name="Read Document" width="90" x="45" y="30">
<parameter key="extract_text_only" value="true"/>
<parameter key="use_file_extension_as_type" value="true"/>
<parameter key="content_type" value="txt"/>
<parameter key="encoding" value="UTF-8"/>
<operator activated="true" class="text:process_documents" compatibility="8.2.000" expanded="true" height="103" name="Process Documents" width="90" x="246" y="34">
<parameter key="create_word_vector" value="false"/>
<parameter key="vector_creation" value="TF-IDF"/>
<parameter key="add_meta_information" value="true"/>
<parameter key="keep_text" value="true"/>
<parameter key="prune_method" value="none"/>
<parameter key="prune_below_percent" value="3.0"/>
<parameter key="prune_above_percent" value="30.0"/>
<parameter key="prune_below_rank" value="5.0"/>
<parameter key="prune_above_rank" value="5.0"/>
<parameter key="datamanagement" value="double_sparse_array"/>
<parameter key="data_management" value="auto"/>
<operator activated="true" class="text:tokenize" compatibility="8.2.000" expanded="true" height="68" name="Tokenize" width="90" x="45" y="85">
<parameter key="mode" value="non letters"/>
<parameter key="characters" value=".:"/>
<parameter key="language" value="English"/>
<parameter key="max_token_length" value="3"/>
<operator activated="true" class="text:transform_cases" compatibility="8.2.000" expanded="true" height="68" name="Transform Cases" width="90" x="179" y="85">
<parameter key="transform_to" value="upper case"/>
<operator activated="true" class="text:filter_stopwords_dictionary" compatibility="8.2.000" expanded="true" height="82" name="Filter Stopwords (Dictionary)" width="90" x="313" y="85">
<parameter key="file" value="C:\Users\jphillips\Downloads\sw.txt"/>
<parameter key="case_sensitive" value="false"/>
<operator activated="true" class="text:filter_by_length" compatibility="8.2.000" expanded="true" height="68" name="Filter Tokens (by Length)" width="90" x="514" y="85">
<parameter key="min_chars" value="4"/>
<parameter key="max_chars" value="25"/>
<operator activated="true" class="text:generate_n_grams_terms" compatibility="8.2.000" expanded="true" height="68" name="Generate n-Grams (Terms)" width="90" x="715" y="136">
<parameter key="max_length" value="3"/>
<connect from_port="document" to_op="Tokenize" to_port="document"/>
<connect from_op="Tokenize" from_port="document" to_op="Transform Cases" to_port="document"/>
<connect from_op="Transform Cases" from_port="document" to_op="Filter Stopwords (Dictionary)" to_port="document"/>
<connect from_op="Filter Stopwords (Dictionary)" from_port="document" to_op="Filter Tokens (by Length)" to_port="document"/>
<connect from_op="Filter Tokens (by Length)" from_port="document" to_op="Generate n-Grams (Terms)" to_port="document"/>
<connect from_op="Generate n-Grams (Terms)" from_port="document" to_port="document 1"/>
</process>
<operator activated="true" class="text:wordlist_to_data" compatibility="8.2.000" expanded="true" height="82" name="WordList to Data" width="90" x="447" y="34"/>
<operator activated="true" class="multiply" compatibility="9.3.001" expanded="true" height="103" name="Multiply" width="90" x="581" y="34"/>
<operator activated="true" class="r_scripting:execute_r" compatibility="9.1.000" expanded="true" height="103" name="Execute R" width="90" x="782" y="187">
<parameter key="script" value="# rm_main is a mandatory function, # the number of arguments has to be the number of input ports (can be none) rm_main = function(data) { 	library("wordcloud") 	library("RColorBrewer") 	Encoding(data$word) <- "UTF-8" 	 	png("C:\\CENDOC\\output\\WordClouds\\%{file_name_TEST}_word_list.png", width=1280,height=800) 	wordcloud(words = data$word, freq = data$total, min.freq = 1, max.words=100, lang= "spanish", random.order=FALSE, rot.per=0.35, colors=brewer.pal(8, "Dark2")) 	dev.off() 	 	return (data) } "/>
<operator activated="true" class="write_excel" compatibility="9.2.001" expanded="true" height="103" name="Write Excel" width="90" x="782" y="34">
<parameter key="excel_file" value="C:\CENDOC\output\Excel\%{file_name_TEST}_word_list.xlsx"/>
<parameter key="file_format" value="xlsx"/>
<enumeration key="sheet_names"/>
<parameter key="sheet_name" value="RapidMiner Data"/>
<parameter key="date_format" value="yyyy-MM-dd HH:mm:ss"/>
<parameter key="number_format" value="#.0"/>
<connect from_port="file object" to_op="Read Document" to_port="file"/>
<connect from_op="Read Document" from_port="output" to_op="Process Documents" to_port="documents 1"/>
<connect from_op="Process Documents" from_port="word list" to_op="WordList to Data" to_port="word list"/>
<connect from_op="WordList to Data" from_port="example set" to_op="Multiply" to_port="input"/>
<connect from_op="Multiply" from_port="output 1" to_op="Write Excel" to_port="input"/>
<connect from_op="Multiply" from_port="output 2" to_op="Execute R" to_port="input 1"/>
<connect from_op="Execute R" from_port="output 1" to_port="out 2"/>
<connect from_op="Write Excel" from_port="through" to_port="out 1"/>
<portSpacing port="source_file object" spacing="0"/>
<portSpacing port="sink_out 3" spacing="0"/>
</process>
<operator activated="false" class="append" compatibility="9.3.001" expanded="true" height="68" name="Append" width="90" x="313" y="340">
<parameter key="datamanagement" value="double_array"/>
<parameter key="merge_type" value="all"/>
<connect from_op="Loop Files" from_port="out 1" to_port="result 1"/>
</process>
</process>
rfuentealba
Does filtering by if the record contains a
_
work? Like, if you have n-grams, 1-grams won't contain this character.
All the best,
Rodrigo.
jmphillips
filter tokens (by XXXX).
jmphillips
creo que es mejor hablar en español, ya que los 2 lo hacemos.. !!! jjjjj
rfuentealba
Hola, así es.
¿Es posible importar el proceso como XML y enviármelo? Así puedo hacerme a la idea y ver si puedo ayudarte.
Saludos,
Rodrigo.
jmphillips
<context>
<input/>
<output/>
<macros/>
</context>
</process>
</process>
</process>
</process>
