two data sets
[Deleted User]
Hi
I have two excel form of data and one of them has Label the other one doesnt have label column so is it possible to import both of them to RM and start use ML algorithms for them?
Thank you
mbs
varunm1
Hello
@mbs
Yes, you can. You do not need a label for importing. If both of these datasets are related, you can train the algorithm on a dataset with labels and use the apply model to predict labels for the dataset without labels.
Hope this helps. Please inform if you have more questions.
varunm1
I attached a sample process using Titanic labeled and unlabelled datasets for your reference. You can import the .rmp file.
Thanks
Process.rmp
varunm1
Hello
@mbs
[Deleted User]
@varunm1
Thank you for your quick answer.
I will try it
regards
mbs
varunm1
Thanks
Process.rmp
[Deleted User]
@varunm1
Thank you very much
best regards
mbs
@varunm1
از راهنمایی شما خیلی ممنونم
با احترام
mbs
[Deleted User]
@varunm1
I import your rmp file but unfortunately I see a problem that shows some columns doesnt match with each other but I check the data and it doesnt have any problem. please
guide me to solve it.
Thank you
mbs
[Deleted User]
yes
varunm1
Hello
@mbs
Can you set a breakpoint before apply model by right clicking on the apply model operator? Once you set it, run the process and see if the attribute is available, if it is available see what the type (numeric, polynomial etc) of that attribute is. You can also see what type of attribute is coming from the training data set by setting break point after read excel (training data).
[Deleted User]
@varunm1
all my data is in binary form but I think this is not the problem of data and its like a bug and i couldnt handle it.
mbs
varunm1
You can send me your data and process in direct message for checking.
[Deleted User]
sure
I did it
[Deleted User]
@varunm1
Hello
I changed all the columns header (type dote between words) but still I see so many bugs
And no thing work
please help me to solve it
regards
mbs
varunm1
Can you post the images of those bugs?
[Deleted User]
names dont have any problem
varunm1
If you have the attribute available in both data sets and they belong to the same data type (polnomial, integer etc), from my understanding its the Names issue (spaces). Lets see if
@sgenzer
or
@mschmitz
MartinLiebig
this UserError just states, that the data set you apply the model on (the lowerone) doesnot contain the attribute WRITE.CONTACTS. Please verify that it exists andis not special.
BR,
Martin
[Deleted User]
@mschmitz
Hi
In both data I have the same attribute " write.contacts".
But still I see the error.
regards
mbs
MartinLiebig
hi,
keep in mind that captial letters play a role. is this writtena lso all in caps?
Best,
Martin
varunm1
Hello Martin,
@mschmitz
can the spaces before the start of names in excel impact RM attributes if we use read excel operator?
[Deleted User]
@mschmitz
Yes you see the exact form of writing with captial letters in both of them.
Thank you
mbs
