Dear Rapidminer Team,
I set up a Rapidminer Server via your AWS (BYOL) builds, set up a server repository and connected it to the server. So far so good.
My problem is now that when I try to run a process I stored in the Rapidminer Server repository I only get fails with this error message:
Cannot retrieve repository data
Cannot retrieve repository data from entry '//XXX/2 Data/Test1'. Reason: Requested repository XXX does not exist..
I can see the repository in the Web UI and when I run processes locally everything works but as soon as I start the process via the web interface it fails.
Did I miss to set a certain connection?
I hope you can help me!
Best regards
Felix
