Prediction Analysis of text documents
lambamanika07
The same process was giving results before but now its showing to 'set role' but as I am using text files I do not know how to solve this problem.
Text Mining + NLP
lionelderkrikor
@lambamanika07
Based on the error you sent in PM (which is more explicit), can you set in the
Split Validation
operator parameters, set
sampling type
shuffled sampling
(instead
automatic
Lionel
lionelderkrikor
Hi
@lambamanika07
Can you please attach here in the forum :
- your data
- your process (via
File
Export Process
Can you precise what you want to do ?
Thanks,
Lionel
varunm1
Hello
@lambamanika07
Are you getting an error after running the process? If not, this is just a warning.
lambamanika07
Hi Lionel
Can I send you the data in private message?
lionelderkrikor
Yes,
@lambamanika07
you can send me the data via private message.
Lionel
lambamanika07
Hi Varun
The process does not run. It gets stop and shows this error
varunm1
@lionelderkrikor
can help if you provide data and process file as he requested.
lambamanika07
Hi
@lionelderkrikor
As suggested by you, I performed the process with 441 full text files but the following error is showing. Kindly suggest how to overcome this.
lionelderkrikor
@lambamanika07
Split Validation
sampling type
shuffled sampling
(instead
automatic
Lionel
