<?xml version="1.0" encoding="UTF-8"?><process version="9.4.000-BETA"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="9.4.000-BETA" expanded="true" name="Process" origin="GENERATED_TUTORIAL"> <parameter key="logverbosity" value="init"/> <parameter key="random_seed" value="2001"/> <parameter key="send_mail" value="never"/> <parameter key="notification_email" value=""/> <parameter key="process_duration_for_mail" value="30"/> <parameter key="encoding" value="SYSTEM"/> <process expanded="true"> <operator activated="true" class="retrieve" compatibility="9.4.000-BETA" expanded="true" height="68" name="Retrieve Deals" origin="GENERATED_TUTORIAL" width="90" x="45" y="34"> <parameter key="repository_entry" value="//Samples/data/Deals"/> </operator> <operator activated="true" class="h2o:logistic_regression" compatibility="9.3.001" expanded="true" height="124" name="Logistic Regression" origin="GENERATED_TUTORIAL" width="90" x="179" y="34"> <parameter key="solver" value="AUTO"/> <parameter key="reproducible" value="true"/> <parameter key="maximum_number_of_threads" value="4"/> <parameter key="use_regularization" value="false"/> <parameter key="lambda_search" value="false"/> <parameter key="number_of_lambdas" value="0"/> <parameter key="lambda_min_ratio" value="0.0"/> <parameter key="early_stopping" value="true"/> <parameter key="stopping_rounds" value="3"/> <parameter key="stopping_tolerance" value="0.001"/> <parameter key="standardize" value="true"/> <parameter key="non-negative_coefficients" value="false"/> <parameter key="add_intercept" value="true"/> <parameter key="compute_p-values" value="true"/> <parameter key="remove_collinear_columns" value="true"/> <parameter key="missing_values_handling" value="MeanImputation"/> <parameter key="max_iterations" value="0"/> <parameter key="max_runtime_seconds" value="0"/> </operator> <operator activated="true" class="generate_macro" compatibility="9.4.000-BETA" expanded="true" height="82" name="Generate Macro" width="90" x="313" y="136"> <list key="function_descriptions"> <parameter key="seed" value="date_millis(date_now())%1000"/> </list> <description align="center" color="transparent" colored="false" width="126">a &quot;random&quot; seed</description> </operator> <operator activated="true" class="shuffle" compatibility="9.4.000-BETA" expanded="true" height="82" name="Shuffle" width="90" x="447" y="238"> <parameter key="use_local_random_seed" value="true"/> <parameter key="local_random_seed" value="%{seed}"/> </operator> <operator activated="true" class="write_csv" compatibility="9.4.000-BETA" expanded="true" height="82" name="Write CSV" width="90" x="581" y="136"> <parameter key="column_separator" value=";"/> <parameter key="write_attribute_names" value="true"/> <parameter key="quote_nominal_values" value="true"/> <parameter key="format_date_attributes" value="true"/> <parameter key="append_to_file" value="false"/> <parameter key="encoding" value="SYSTEM"/> </operator> <operator activated="true" class="read_csv" compatibility="9.4.000-BETA" expanded="true" height="68" name="Read CSV" width="90" x="715" y="136"> <parameter key="column_separators" value=";"/> <parameter key="trim_lines" value="false"/> <parameter key="use_quotes" value="true"/> <parameter key="quotes_character" value="""/> <parameter key="escape_character" value="\"/> <parameter key="skip_comments" value="false"/> <parameter key="comment_characters" value="#"/> <parameter key="starting_row" value="1"/> <parameter key="parse_numbers" value="true"/> <parameter key="decimal_character" value="."/> <parameter key="grouped_digits" value="false"/> <parameter key="grouping_character" value=","/> <parameter key="infinity_representation" value=""/> <parameter key="date_format" value=""/> <parameter key="first_row_as_names" value="true"/> <list key="annotations"/> <parameter key="time_zone" value="SYSTEM"/> <parameter key="locale" value="English (United States)"/> <parameter key="encoding" value="SYSTEM"/> <parameter key="read_all_values_as_polynominal" value="false"/> <list key="data_set_meta_data_information"/> <parameter key="read_not_matching_values_as_missings" value="true"/> <parameter key="datamanagement" value="double_array"/> <parameter key="data_management" value="auto"/> </operator> <operator activated="true" class="set_role" compatibility="9.4.000-BETA" expanded="true" height="82" name="shuffled data" width="90" x="849" y="136"> <parameter key="attribute_name" value="Future Customer"/> <parameter key="target_role" value="label"/> <list key="set_additional_roles"/> </operator> <operator activated="true" class="h2o:logistic_regression" compatibility="9.3.001" expanded="true" height="124" name="Logistic Regression shuffled" origin="GENERATED_TUTORIAL" width="90" x="983" y="136"> <parameter key="solver" value="AUTO"/> <parameter key="reproducible" value="true"/> <parameter key="maximum_number_of_threads" value="4"/> <parameter key="use_regularization" value="false"/> <parameter key="lambda_search" value="false"/> <parameter key="number_of_lambdas" value="0"/> <parameter key="lambda_min_ratio" value="0.0"/> <parameter key="early_stopping" value="true"/> <parameter key="stopping_rounds" value="3"/> <parameter key="stopping_tolerance" value="0.001"/> <parameter key="standardize" value="true"/> <parameter key="non-negative_coefficients" value="false"/> <parameter key="add_intercept" value="true"/> <parameter key="compute_p-values" value="true"/> <parameter key="remove_collinear_columns" value="true"/> <parameter key="missing_values_handling" value="MeanImputation"/> <parameter key="max_iterations" value="0"/> <parameter key="max_runtime_seconds" value="0"/> </operator> <connect from_op="Retrieve Deals" from_port="output" to_op="Logistic Regression" to_port="training set"/> <connect from_op="Logistic Regression" from_port="model" to_port="result 1"/> <connect from_op="Logistic Regression" from_port="exampleSet" to_op="Generate Macro" to_port="through 1"/> <connect from_op="Generate Macro" from_port="through 1" to_op="Shuffle" to_port="example set input"/> <connect from_op="Shuffle" from_port="example set output" to_op="Write CSV" to_port="input"/> <connect from_op="Shuffle" from_port="original" to_port="result 4"/> <connect from_op="Write CSV" from_port="file" to_op="Read CSV" to_port="file"/> <connect from_op="Read CSV" from_port="output" to_op="shuffled data" to_port="example set input"/> <connect from_op="shuffled data" from_port="example set output" to_op="Logistic Regression shuffled" to_port="training set"/> <connect from_op="Logistic Regression shuffled" from_port="model" to_port="result 2"/> <connect from_op="Logistic Regression shuffled" from_port="exampleSet" to_port="result 3"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="63"/> <portSpacing port="sink_result 3" spacing="21"/> <portSpacing port="sink_result 4" spacing="84"/> <portSpacing port="sink_result 5" spacing="21"/> </process> </operator> </process>
