Stuck at LDA process. No results are coming
lambamanika07
I updated my Rapidminer and from that instant I can not get any result from my LDA process. I am attaching the screenshot for the process and the sub-processes I am trying out for LDA for last 2-3 days but 'NA' as results is showing. Kindly help.
MartinLiebig
Hi
@lambamanika07
your file is coded in UTF-8. If you are using windows, you want to change the Encoding of Read Document to UTF-8. Otherwise strange things happend with signs like é.
Further you should use a tokenize operator before your text mining operators. Operators like 'Stem' or 'n-grams' are working on the tokens. This may have duplicated your data.
Lastly: Can you quickly confirm that the number of topics you search is < then the number of documents? If you search for 5 topics in 2 documents, that is doomed to fail.
Best,
Martin
MartinLiebig
can you please check if the collection of documents contains proper documents? I.e there are items in and there is also text?
Best,
Martin
lambamanika07
Hi Martin
Yes, I have checked many times. I tried with text files and pdf files both. I tried even with different text samples but I had no luck! The results were coming like in the screenshot as NA.
MartinLiebig
is this 'western' text? LDA uses a default tokenization on this tokens like spaces and so on. This may totally fail if this is not in latin alphabet?
Best,
Martin
lambamanika07
Hi Martin
The text is in English language. I have run the same samples before also for testing few weeks ago and it worked fine. That time I was using the 8 version of Rapidminer. I am facing this problem from the moment I upgraded to the latest 9 version. I do not think the up gradation of the version would be creating any problem but I am telling you just in case.
MartinLiebig
can you maybe share data and processes via private message? I would love to have a look at this.
BR,
Martin
lambamanika07
Hi Martin
I have sent you a personal message with the sample text and the process. Thank you for you help in advance.
MartinLiebig
Hi
@lambamanika07
Best,
Martin
lambamanika07
It worked! Thank you so much.
MartinLiebig
Hey
@lambamanika07
what was the problem here? UTF or the tokenization?
BR,
Martin
lambamanika07
Hey Martin
I made both the changes regarding UTF selection and adding tokenization operator as suggested in the process and then it worked.
With regards
Manika
