I asked a question a few days ago about how to get the top5 of clients according to the criteria that they will choose, to which I got as an answer to use the Sort operator and then Filter Example Range. It worked, since it throws me the values in a table with the 5 best ones, as you told me in your comment, because I used the Sort operator. Then use "Filter example range" with the first example = 1 and the last example = 5 to get only the first 5 following your instructions. However, it tells me that there is a "potential problem detected: the first_example parameter indexes an example, but the value 1 exceeds the size of the set of examples". What do you mean by that mistake? How can I solve it?
