package com.rapidminer.extension.operator.blending;import java.util.ArrayList;import java.util.Arrays;import java.util.List;import com.rapidminer.example.Attribute;import com.rapidminer.example.Example;import com.rapidminer.example.ExampleSet;import com.rapidminer.example.table.AttributeFactory;import com.rapidminer.example.utils.ExampleSetBuilder;import com.rapidminer.example.utils.ExampleSets;import com.rapidminer.operator.Operator;import com.rapidminer.operator.OperatorDescription;import com.rapidminer.operator.UserError;import com.rapidminer.operator.ports.InputPort;import com.rapidminer.operator.ports.OutputPort;import com.rapidminer.parameter.ParameterType;import com.rapidminer.parameter.ParameterTypeAttribute;import com.rapidminer.parameter.ParameterTypeBoolean;import com.rapidminer.parameter.ParameterTypeCategory;import com.rapidminer.parameter.ParameterTypeDouble;import com.rapidminer.parameter.ParameterTypeInt;import com.rapidminer.parameter.conditions.EqualStringCondition;import com.rapidminer.tools.Ontology;public class CrossTable extends Operator { InputPort exaInput = getInputPorts().createPort("exa"); OutputPort crossOutput = getOutputPorts().createPort("cro"); OutputPort crossOut = getOutputPorts().createPassThroughPort("ori"); public final static String PARAMETER_X_ATTRIBTUE = "x_attribute"; public final static String PARAMETER_Y_ATTRIBTUE = "y_attribute"; public CrossTable(OperatorDescription description) { super(description); } public void doWork() throws UserError { ExampleSet exampleSet = exaInput.getData(ExampleSet.class); Attribute x = exampleSet.getAttributes().get(getParameterAsString(PARAMETER_X_ATTRIBTUE)); Attribute y = exampleSet.getAttributes().get(getParameterAsString(PARAMETER_Y_ATTRIBTUE)); Integer xSize = x.getMapping().getValues().size(); Integer ySize = y.getMapping().getValues().size(); double[][] values = new double[xSize + 1][ySize + 2];// Initialize with 0s for (int xCounter = 0; xCounter < xSize + 1; ++xCounter) { for (int yCounter = 1; yCounter < ySize + 2; ++yCounter) { values[xCounter][yCounter] = 0; } }// Add the names Attribute nameAttribute = AttributeFactory.createAttribute("name",Ontology.POLYNOMINAL); for (int xCounter = 0; xCounter < xSize; ++xCounter) { values[xCounter][0] = nameAttribute.getMapping().mapString(x.getMapping().getValues().get(xCounter)); } values[xSize][0] = nameAttribute.getMapping().mapString("sum");// sum! for (Example exa : exampleSet) { int xIndex = x.getMapping().getValues().indexOf(exa.getNominalValue(x)); int yIndex = y.getMapping().getValues().indexOf(exa.getNominalValue(y)); values[xIndex][yIndex+1] += 1; } for (int xCounter = 0; xCounter < xSize; ++xCounter) { double ySum = 0; for (int yCounter = 0; yCounter < ySize; ++yCounter) { ySum += values[xCounter][yCounter+1]; } values[xCounter][ySize+1] = ySum; } for (int yCounter = 0; yCounter < ySize; ++yCounter) { double xSum = 0; for (int xCounter = 0; xCounter < xSize; ++xCounter) { xSum += values[xCounter][yCounter+1]; } values[xSize][yCounter+1] = xSum; } values[xSize][ySize+1] = exampleSet.size(); List<Attribute> listOfAttributes = new ArrayList<Attribute>(); listOfAttributes.add(nameAttribute); for (String value : y.getMapping().getValues()) { listOfAttributes.add(AttributeFactory.createAttribute("count(" + value + ")", Ontology.REAL)); } listOfAttributes.add(AttributeFactory.createAttribute("sum", Ontology.REAL)); ExampleSetBuilder builder = ExampleSets.from(listOfAttributes); for(double[] row : values){ builder.addRow(row); } crossOutput.deliver(builder.build()); }@Override public List<ParameterType> getParameterTypes() { List<ParameterType> types = new ArrayList<>(); types.add(new ParameterTypeAttribute(PARAMETER_X_ATTRIBTUE,"Attribute to construct the horizontal axis.",exaInput)); types.add(new ParameterTypeAttribute(PARAMETER_Y_ATTRIBTUE,"Attribute to construct the vertical axis.",exaInput)); return types; }}
data.loc['Total']= data.sum()</code><?xml version="1.0" encoding="UTF-8"?><process version="9.3.001"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="9.3.001" expanded="true" name="Process"> <parameter key="logverbosity" value="init"/> <parameter key="random_seed" value="2001"/> <parameter key="send_mail" value="never"/> <parameter key="notification_email" value=""/> <parameter key="process_duration_for_mail" value="30"/> <parameter key="encoding" value="SYSTEM"/> <process expanded="true"> <operator activated="true" class="generate_nominal_data" compatibility="9.3.001" expanded="true" height="68" name="Generate Nominal Data" width="90" x="45" y="34"> <parameter key="number_examples" value="100"/> <parameter key="number_of_attributes" value="1"/> <parameter key="number_of_values" value="5"/> <parameter key="use_local_random_seed" value="false"/> <parameter key="local_random_seed" value="1992"/> </operator> <operator activated="true" class="blending:pivot" compatibility="9.3.001" expanded="true" height="82" name="Pivot" width="90" x="179" y="34"> <parameter key="group_by_attributes" value="att1"/> <parameter key="column_grouping_attribute" value="label"/> <list key="aggregation_attributes"> <parameter key="label" value="count"/> </list> <parameter key="use_default_aggregation" value="false"/> <parameter key="default_aggregation_function" value="first"/> </operator> <operator activated="true" class="rename_by_replacing" compatibility="9.3.001" expanded="true" height="82" name="Rename by Replacing" width="90" x="313" y="34"> <parameter key="attribute_filter_type" value="single"/> <parameter key="attribute" value="att1"/> <parameter key="attributes" value=""/> <parameter key="use_except_expression" value="false"/> <parameter key="value_type" value="attribute_value"/> <parameter key="use_value_type_exception" value="false"/> <parameter key="except_value_type" value="time"/> <parameter key="block_type" value="attribute_block"/> <parameter key="use_block_type_exception" value="false"/> <parameter key="except_block_type" value="value_matrix_row_start"/> <parameter key="invert_selection" value="true"/> <parameter key="include_special_attributes" value="false"/> <parameter key="replace_what" value=".*_"/> </operator> <operator activated="true" class="replace_missing_values" compatibility="9.3.001" expanded="true" height="103" name="Replace Missing Values" width="90" x="514" y="34"> <parameter key="return_preprocessing_model" value="false"/> <parameter key="create_view" value="false"/> <parameter key="attribute_filter_type" value="all"/> <parameter key="attribute" value=""/> <parameter key="attributes" value=""/> <parameter key="use_except_expression" value="false"/> <parameter key="value_type" value="attribute_value"/> <parameter key="use_value_type_exception" value="false"/> <parameter key="except_value_type" value="time"/> <parameter key="block_type" value="attribute_block"/> <parameter key="use_block_type_exception" value="false"/> <parameter key="except_block_type" value="value_matrix_row_start"/> <parameter key="invert_selection" value="false"/> <parameter key="include_special_attributes" value="false"/> <parameter key="default" value="zero"/> <list key="columns"/> </operator> <operator activated="true" class="generate_aggregation" compatibility="9.3.001" expanded="true" height="82" name="Generate Aggregation" width="90" x="648" y="34"> <parameter key="attribute_name" value="Total_Column"/> <parameter key="attribute_filter_type" value="single"/> <parameter key="attribute" value="att1"/> <parameter key="attributes" value=""/> <parameter key="use_except_expression" value="false"/> <parameter key="value_type" value="attribute_value"/> <parameter key="use_value_type_exception" value="false"/> <parameter key="except_value_type" value="time"/> <parameter key="block_type" value="attribute_block"/> <parameter key="use_block_type_exception" value="false"/> <parameter key="except_block_type" value="value_matrix_row_start"/> <parameter key="invert_selection" value="true"/> <parameter key="include_special_attributes" value="false"/> <parameter key="aggregation_function" value="sum"/> <parameter key="concatenation_separator" value="|"/> <parameter key="keep_all" value="true"/> <parameter key="ignore_missings" value="true"/> <parameter key="ignore_missing_attributes" value="false"/> </operator> <operator activated="true" class="transpose" compatibility="9.3.001" expanded="true" height="82" name="Transpose" width="90" x="782" y="34"/> <operator activated="true" class="rename_by_example_values" compatibility="9.3.001" expanded="true" height="82" name="Rename by Example Values" width="90" x="916" y="34"> <parameter key="row_number" value="1"/> </operator> <operator activated="true" class="parse_numbers" compatibility="9.3.001" expanded="true" height="82" name="Parse Numbers" width="90" x="1050" y="34"> <parameter key="attribute_filter_type" value="all"/> <parameter key="attribute" value=""/> <parameter key="attributes" value=""/> <parameter key="use_except_expression" value="false"/> <parameter key="value_type" value="nominal"/> <parameter key="use_value_type_exception" value="false"/> <parameter key="except_value_type" value="file_path"/> <parameter key="block_type" value="single_value"/> <parameter key="use_block_type_exception" value="false"/> <parameter key="except_block_type" value="single_value"/> <parameter key="invert_selection" value="false"/> <parameter key="include_special_attributes" value="false"/> <parameter key="decimal_character" value="."/> <parameter key="grouped_digits" value="false"/> <parameter key="grouping_character" value=","/> <parameter key="infinity_representation" value=""/> <parameter key="unparsable_value_handling" value="fail"/> </operator> <operator activated="true" class="generate_aggregation" compatibility="9.3.001" expanded="true" height="82" name="Generate Aggregation (2)" width="90" x="1184" y="34"> <parameter key="attribute_name" value="Total_Row"/> <parameter key="attribute_filter_type" value="single"/> <parameter key="attribute" value="att1"/> <parameter key="attributes" value=""/> <parameter key="use_except_expression" value="false"/> <parameter key="value_type" value="attribute_value"/> <parameter key="use_value_type_exception" value="false"/> <parameter key="except_value_type" value="time"/> <parameter key="block_type" value="attribute_block"/> <parameter key="use_block_type_exception" value="false"/> <parameter key="except_block_type" value="value_matrix_row_start"/> <parameter key="invert_selection" value="true"/> <parameter key="include_special_attributes" value="true"/> <parameter key="aggregation_function" value="sum"/> <parameter key="concatenation_separator" value="|"/> <parameter key="keep_all" value="true"/> <parameter key="ignore_missings" value="false"/> <parameter key="ignore_missing_attributes" value="false"/> </operator> <operator activated="true" class="transpose" compatibility="9.3.001" expanded="true" height="82" name="Transpose (2)" width="90" x="1050" y="238"/> <connect from_op="Generate Nominal Data" from_port="output" to_op="Pivot" to_port="input"/> <connect from_op="Pivot" from_port="output" to_op="Rename by Replacing" to_port="example set input"/> <connect from_op="Rename by Replacing" from_port="example set output" to_op="Replace Missing Values" to_port="example set input"/> <connect from_op="Replace Missing Values" from_port="example set output" to_op="Generate Aggregation" to_port="example set input"/> <connect from_op="Generate Aggregation" from_port="example set output" to_op="Transpose" to_port="example set input"/> <connect from_op="Transpose" from_port="example set output" to_op="Rename by Example Values" to_port="example set input"/> <connect from_op="Rename by Example Values" from_port="example set output" to_op="Parse Numbers" to_port="example set input"/> <connect from_op="Parse Numbers" from_port="example set output" to_op="Generate Aggregation (2)" to_port="example set input"/> <connect from_op="Generate Aggregation (2)" from_port="example set output" to_op="Transpose (2)" to_port="example set input"/> <connect from_op="Transpose (2)" from_port="example set output" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator> </process> </pre><div>Another way is using the Python process<br>and use this line of code to add a row with the totals of each column<br><pre class="CodeBlock"><code>#
